#1 Replace Sump Gasket
thomen Posted on: 2012/7/23 7:46
Hi Guys,
I appear to have a leak from around my sump gasket. I have bought a new one but am wondering what are the rubber half circle shaped rings for? as seen here: http://datsun1200.com/modules/mediawiki/index.php?title=Oil_pan
Do I apply sealant to them? my service manual doesn't mention anything about re-fitting one.. just to remove 16 screws to remove the sump..
just wondering what gasket goo people would suggest? (if any i know the wiki said none on the cork parts of the gasket but i was wondering if that is correct?
Cheers,
Tom
#2 Re: Replace Sump Gasket
ddgonzal Posted on: 2012/7/23 8:21
The half-rounds are for the ends of the sump
a dab of RTV sealer on the ends where the half-round gaskets meet the rail-sides. Do not put very much on
#3 Re: Replace Sump Gasket
thomen Posted on: 2012/7/23 8:38
Thank you! I just can't picture which side of the round circle needs the goo..
is it where the yellowy arrows are or all around the outer diameter or all around the inner diameter?
gif  gasket.gif (4.17 KB)
12667_500cff889fab5.gif 200X200 px
#4 Re: Replace Sump Gasket
ddgonzal Posted on: 2012/7/23 18:22
Not on the sides, but "on the ends" -- where the half-round gaskets meet the rail-sides.
#5 Re: Replace Sump Gasket
thomen Posted on: 2012/7/24 5:53
Would you happen to have any pics as my manual has nothing at all.
Cheers,
Tom
#6 Re: Replace Sump Gasket
ddgonzal Posted on: 2012/7/24 6:27
You should get a Datsun factory service manual, it has a photo.
It does not go on *any* part of the round area. It goes on the flat part where the half-rounds meet the side rails. Where the black rubber pieces meet the cork pieces. The block has a step-down right there. Put a touch of RTV in the steps.
#7 Re: Replace Sump Gasket
thomen Posted on: 2012/7/24 6:50
Cheers,
Thank you that description makes sense! I should get a factory service manual! :)
Thanks for your help!
