« 1 ... 17 18 19 (20) 21 22 23 ... 49 »
Re: Datsun 1200 sedan project..
From Trinidad and tobago
Does anyone know the Timing Settings For the a15 engine?
Thanks.
Posted on: 2012/7/20 2:21
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
Yesterday i started to Pull apart the engine,we are certain that this engine was never opened befor by the looks of some bolts From the oil pump and Alternator bracket.
jpg  Pic0720001.jpg (91.17 KB)
12526_500aecb6c5659.jpg 986X789 px
jpg  Pic0720002.jpg (89.46 KB)
12526_500aed0ea911b.jpg 986X789 px
jpg  Pic0720003.jpg (102.93 KB)
12526_500aed250ae45.jpg 986X789 px
jpg  Pic0720004.jpg (71.24 KB)
12526_500aed410d59d.jpg 986X789 px
jpg  Pic0720005.jpg (101.46 KB)
12526_500aee666f81d.jpg 986X789 px
jpg  Pic0721001.jpg (116.45 KB)
12526_500aee7f1e133.jpg 986X789 px
jpg  Pic0721002.jpg (108.83 KB)
12526_500aefa25b4dd.jpg 986X789 px
jpg  Pic0721003.jpg (116.08 KB)
12526_500aefce8634e.jpg 789X986 px
jpg  Pic0721004.jpg (125.69 KB)
12526_500af02aaf194.jpg 986X789 px
jpg  Pic0721010.jpg (119.96 KB)
12526_500af04602548.jpg 986X789 px
jpg  Pic0721009.jpg (146.69 KB)
12526_500af0784b844.jpg 986X789 px
jpg  Pic0721011.jpg (131.66 KB)
12526_500af09e31fd5.jpg 986X789 px
Posted on: 2012/7/21 19:10
Street Sleeper!
Same as for the A12 engine. Technically, it depends on the distributor you are using. You want about 34 degrees full advance at 4400 RPM. So the initial timing setting should be 34 degrees LESS the mechanical advance, which varies by distributor.
If you set if for 7 degrees BTDC it will work fine with any A-series engine and any stock distributor. But you might get a little more power by fine-tuning it.
Posted on: 2012/7/21 23:14
Thanks for the info.
Got a little bit more work done striping it,We took of the flywheel,water pumphousing..Today we are going to strip it form the bottom then pull the pistons from below since we cant get of the cylinderhead because three bolts lock it,because of rust of over a period of time.
Pics.
jpg  Pic07 21003.jpg (60.22 KB)
12526_500e98db7becb.jpg 693X555 px
jpg  Pic0721 002.jpg (52.77 KB)
12526_500e994031db2.jpg 693X555 px
jpg  Pic07210 01.jpg (72.44 KB)
12526_500e996ac41a6.jpg 693X555 px
Posted on: 2012/7/24 13:47
Street Sleeper!
looks ike a good base. a15 is good over an a12 but dont expect a power house over an a12. the extra torque and hp is worth it. now save for dual carbs and a cam with it
Posted on: 2012/7/24 14:30
Ok So i made some Progress today.
Took out main an conrod bearings also the crankshaft Jornals in pretty good shape .Maybe I Should lighten the crank.
jpg  Pic0724001.jpg (109.75 KB)
12526_500f71f8dbea8.jpg 789X986 px
jpg  Pic0724002.jpg (96.59 KB)
12526_500f7282e6709.jpg 896X717 px
jpg  Pic0724003.jpg (93.64 KB)
12526_500f72ac56ed5.jpg 896X717 px
jpg  Pic0724004.jpg (53.06 KB)
12526_500f737f6e328.jpg 896X717 px
jpg  Pic0724006.jpg (103.39 KB)
12526_500f74723898b.jpg 896X717 px
jpg  Pic0724005.jpg (84.87 KB)
12526_500f74e78eff5.jpg 896X717 px
Posted on: 2012/7/25 5:24
Street Sleeper!
Ok so besides The a15 in progess,I have to change my Dizzy on the A12 because of the broken springs in it,Not much power at take off But when it picks up,runs very well and climbing steep hills are a bit of trouble.
So ive Sorce a cheap one off another a12 from a Faimly that has a b120.So i'll chuck it in today..
Posted on: 2012/7/26 19:44
Street Sleeper!
Dropped the head and block off for cylinder head bolts to be drilled out,should get it back in the next 3 days.
Cheers Darren.
Posted on: 2012/7/28 4:11
Street Sleeper!
From dominican republic
good to hear :) hope you get it running well soon
Posted on: 2012/7/28 14:06
Thank you mpower.
Something depressing happen today.Driving on the highway,then all of a sudden ''WAPP'' bonet flips open.Was a bit frightening, pulled on the shoulder to see what happed .Bonet was in a mess flipped back and hit the hood at top of windsheild ,seems that the hinge ketch FAILED.Ponged It out but im Happy that everyone that was in the car is ok.Could have been worse.
jpg  Pic0728001.jpg (52.32 KB)
12526_5014b41a40f6b.jpg 896X717 px
jpg  Pic0728005.jpg (83.47 KB)
12526_5014b4b988b32.jpg 896X717 px
jpg  Pic0728006.jpg (61.90 KB)
12526_5014b4ee4983f.jpg 896X717 px
jpg  Pic0728009.jpg (68.43 KB)
12526_5014b5a4ee0e8.jpg 896X717 px
jpg  Pic0728008.JPG (96.71 KB)
12526_5014b605a4e86.jpg 896X717 px
jpg  Pic0728011.jpg (66.69 KB)
12526_5014b6895830e.jpg 640X480 px
jpg  Pic0728012.jpg (75.35 KB)
12526_5014b6c214fbb.jpg 640X480 px
Posted on: 2012/7/29 5:07
Street Sleeper!
