« 1 2 3 (4) 5 6 »
Re: I am a VSCCS Engineer - NSW Registration of Modified/Altered Vehicles
From SYDNEY,NSW
awesome , thankyou for providing your time and services to the forum!
Posted on: 2012/7/19 4:53
vouch points for PIGDOG J-Dat dats-me TRAV 40RST minitruckin 120fly DEMO 1200dat aidaniel matty discobob mick1200 cemax DATSKOOL - all have helped me out with parts...Thankyou
Quite a regular
From newcastle
so is it legal to put the ca18det in a 1200 ute and have it registered in nsw now? i only ask because i have had this project going for about 7 years and want to know if this is still doable, many thanks
Posted on: 2012/7/24 11:39
at first you dont succeed, cut a bit out and put a bigger one in!
85 1200 ute ca18det project build
From Sydney
mattkinsela - Yes, it always has been legal hasn't it? Whilst some may not know this, the 1200 ute, being a ute, is considered a 'commercial vehicle' and is therefore exempt from the usual rule relating to engine capacity vs tare weight...
I hope this helps.
Posted on: 2012/7/24 12:33
M.R CORP
Automotive Engineering NSW
VSCCS Licenced Certifier
MVRIA Licenced Motor Vehicle Repairer
how does the chassis come into it? i thought it was limited by the fact 1200s dont have a full chassis
Posted on: 2012/7/24 20:38
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
ca18det 1200 ute 180rwkw
Stocko 1200 wagon
From Seattle, WA
1200 utes have a full chassis. Did you mean body-on-frame construction? It does not have a full frame.
Posted on: 2012/7/24 21:12
B110 sedan: L series and 4 speeds, the way they were
From Sydney
Depends how you read the rules. Yes a full chassis would make it a NA category vehicle. Also if the difference in weight between the unladen weight and the GVM is more than twice the weight of the passengers (68kg each) it is considered to be a goods vehicle and therefore a NA category commercial vehicle.
Posted on: 2012/7/25 1:24
M.R CORP
From Melbourne/ Adelaide
Does that mean you can put any engine in a 1200 ute that will fit?
Posted on: 2012/7/25 9:48
oh yea, but it still falls into the sub 800kg category rule im guessing
Posted on: 2012/7/25 10:03
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
Stocko 1200 wagon
From Sydney
Lamb_daiquiri - In theory yes but keep in mind that no engineer is going to put his name on something that is unsafe.
Lethal_john - Where is this 800kg rule? Can you provide a link to it?
Posted on: 2012/7/25 11:59
M.R CORP
Sure, I wouldn't, gaol's not worth it.
Posted on: 2012/7/25 12:05
« 1 2 3 (4) 5 6 »
