Surface rust.
From Goulburn NSW
Hi guys whats the best way yo get ride off surface rust,heres a pic.
jpg  3089ik5_20.jpg (67.08 KB)
14333_5013b78514fde.jpg 800X600 px
Posted on: 2012/7/28 10:57
Re: Surface rust.
From Perth WA AUS
Grind it, sand it but remove it all if you can, then use a rust retarder/converter/primer.
Thats what I did, rust converters from my experience do not work very well, so remove as much rust as you can.
Posted on: 2012/7/28 11:33
Datsun 1200 2Dr sedan.
Re: Surface rust.
From Goldcoast
Sanding works good for me.
Posted on: 2012/7/28 12:10
Re: Surface rust.
From south australia
Sanding won't do by its self. Somerust wi be left Pitted in to the metal. The ideal method is media blasting/ soda blasting. Or go get some deoxodine for
Your local auto shop. It will desolve the rust and clean the metal. Then use a good acid etch primer to make sure it stays away.
Mick
Posted on: 2012/7/28 13:08
Re: Surface rust.
From Goulburn NSW
Guys whats an acid etch primer and can i get that at my local auto shop.
Posted on: 2012/7/29 6:06
Re: Surface rust.
Best way if you have the money is to soda blast it or MAYBE sandblasting, however sandblasting can be risky as it can pitt the metal if not done properly...
I just used a 100mm grinder with a heavy duty wire brush, about 15 dollars a brush and they work a treat!
Posted on: 2012/7/29 8:31
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
Re: Surface rust.
From Goulburn NSW
Hi mate wont a wire brush on grinder leave marks.
Posted on: 2012/7/29 8:50
Re: Surface rust.
From Adelaide
Actually leaves a fairly smooth finish, take care not to over heat the larger panels as that'll stretch them and make the pop in and out....
Posted on: 2012/7/29 9:08
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
Re: Surface rust.
Try ask a crash shop they can usually supply you with what ever you need. People are always coming and ordering paint from the crash shop I work at.
Posted on: 2012/7/29 10:55
Re: Surface rust.
From Perth, West Aussie
http://www.ppc.au.com/corroison_gel.htm
apparently this stuff is the bomb. apparently one of our nation's foremost hotrod builders swears by it (bar a pit of molasses) but if that ain;t practical for ya..
Posted on: 2012/7/29 11:38
