« 1 (2)
Re: Surface rust.
From Goulburn NSW
Hi guys i an planning to do the roof and doors on my project build to get ride off the surface rust,ive sourced the product that im going to use.I am planning to do paint out off a can over the bare metal that im cleaning,will spray can paint be satisfactory until i can get it properly painted.
Posted on: 2012/7/30 8:18
Re: Surface rust.
From Narellan,Sydney
Yea it'll be fine don't let the roof heat up or you buckle it
Posted on: 2012/7/31 4:45
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
Re: Surface rust.
From Goulburn NSW
Hi guys thanks for the info,ive sourced some biodegradable rust stripper.Its call deox-gel and also a product called por-15 to seal it after stripping,its highly recommended so ill give it a go.
Posted on: 2012/7/31 7:06
Re: Surface rust.
From New Zealand
I wouldn't use por15 on roof and doors, to hard to overpaint and is affected by u.v. if exposed to sunlight
Posted on: 2012/7/31 23:28
Re: Surface rust.
From Goulburn NSW
Hi mate its only temperary,it will get rubbed back when i gets painted.Ok if its no good will normal paint from a can keep the rust away after stripping the rust.
Posted on: 2012/8/1 1:57
Re: Surface rust.
Yea all you need is a primer out of a pressure pack.it will be sweet to any bare metal
Posted on: 2012/8/1 5:26
Re: Surface rust.
From Goulburn NSW
Thanks datrotor,
Posted on: 2012/8/1 6:54
« 1 (2)
