215 50 13
From wodonga, victoria
does any one know if it is possible to run a 215 50 13 under a sedan with no flares.
does it rub on the guards at full lock or any thing like that?
thanks
Posted on: 2004/4/6 8:07
Re: 215 50 13
can any one tell me if its possible
Posted on: 2004/4/6 12:18
Re: 215 50 13
From sydney australia
i think it's possible,but you will probably have to lip the guard,which is to tap over the edge on the rear guard.i've run 205 60 13's on 6 inch rims,& always had to lip them.this was mostly to stop the lip cutting into the tyre when going around corners.
Posted on: 2004/4/6 12:23
Re: 215 50 13
Under a sedan? I don't think so. 205s will fit if you have wheels of perfect offset.
Posted on: 2004/4/6 17:14
Re: 215 50 13
From Sydney, Australia
205/60/14s fit on back of a 1200 sedan after getting perfectly offset wheels (custom-made). They, in no way, fit on the front.
So 215/50/13s should fit. But it'll be very close, and you'll have to lip the guards.
Chris
Posted on: 2004/4/6 18:12
Re: 215 50 13
thanks, i think ill keep with the 195 60 14 i already have just wondered if it was possible. it would probably work on a coupe with flares though.'
thanks alot
Posted on: 2004/4/7 2:43
