Quite a regular
Yeh it's back home now, pics coming soon!! and a nice Youtube too, she sounding fantastic and runs soo well. The original motor is the best we've ever seen runs so quiet not a puff of smoke.
Word of comment on Chinese carbys: I've put on a new Chinese (Hitachi copy) carby on it, it works well but we had trouble getting the accelerator pump to work properly so we rejigged the pump from one of my older Hitachi carbys. It fits and now works perfectly. It was also necessary to increase the size of the main jet slightly as the carby was running a bit lean on the airmix ratio curve which is now perfect. Other than that the motor is stock with new water pump, thermostat & housing, all new hoses & rebuilt radiator, serviced fuel pump and new muffler. Ignition is original distributor with points running through a TAI (Transistor Assisted Ignition) unit which I built for the car back in the mid '90s which still works perfect. On the Dyno at the wheels it runs a nice 48hp, pretty much stock figures.
Brakes: All new cylinders, hoses, drums machined, were bleeding OK but for some reason the new brake master cylinder was too short, meaning that the pedal was nearly at the floor when the brakes came on. Fix for this was to jig an adjustable shaft so we could adjust the pedal height in relation to the cylinder. All works good now.. gotta get used to those non power assisted brakes again tho!
Next stage is the bodywork which should begin in about 1 month. In the meantime I'll be stripping the interior ready for trim.
I've decided (for the time being) to keep the car mechanically 100% Stock 1200. It runs so well in this config. It seems everyone else mods their 1200 for some reason. I've come across so many enthusiasts who really love this car and the fact that I've decided to keep it stock - seems just about everyone I meet has had a 1200 as their first car at some stage and they're eager to see this one stay that way because so many others are "non original". Perhaps we'll do the LPG thing in a few years' time.
What I need now is a left rear quarter panel. Does anyone know of anyone (overseas etc) making these aftermarket new? Otherwise looks like I'll be in the market for a 1200 Sedan shell with a good back and only front accident damage. We _can_ fix the one we've got but it's a hell of a lot of work and will probably never be as good as a new one or even one cut out of another car shell.
Looking forward to this one finished one day!
ZM
Posted on: 2012/8/17 10:47
