Re: A15E injection Crank sensor
From Malaysia
Is the dizzy pnp??
I wonder the ECU will get the same reading frm N12 sensor...
Posted on: 2012/8/20 6:30
From Malaysia
ECU
INPUTS
coil negative (tach sense)
air flow meter
air temp sensor (in flow meter)
throttle valve sensor
START wire for ignition switch
water temp sensor (on underside of intake manifold)
O2 sensor (not used for B310, but some ECUs have a wire for it)
OUTPUTS
Injector output
Means no crank sensor input??
Posted on: 2012/8/20 7:25
From Melbourne, Australia
There is no crank sensor
It does read from the module on the distributor
The datto injection, like most (except the very latest modern cars), uses batch fire, it does not need to know which cylinder is firing as it squirts petrol at all of them every time it fires (regardless if inlet valve is open or not)
Posted on: 2012/8/20 22:58
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
In my setup i used a Delco ecu, I simply used the factory electronic dizzy, but exchanged the module for the one to suit a Delco system, It is possible to get factory elec dizzy second hand from USA, but they are usually excessively worn out
I have imported a new one, but it needed a rebuild after i received it as the mechanical advance was poorly weighted and the springs were not strong enough to return the advance after it had moved the first time. Although now it has been rebuilt it has worked great for the last year.
Posted on: 2012/8/20 23:04
1200 Coupe Rallycar
From Malaysia
Thanks for the reply 1200rallycar...
I found out that A15E were using L-Jetronic which some of it didnt use crank signal.(Same as some BMW).
Means it definitely not using Sequential Injection...
Less accurate since it pickup the injection signal frm the dizzy as the dizzy will advance.
But since i hv this A15E injection,i will try to make run 1st...
Might change to some D-Jetronic later n install programmable ecu later...
Posted on: 2012/8/21 1:45
B110 1972 Modded A15
From mandurah
Could overcome the problem of the injector timing advancing parallel to the ignition timing by lockin the dizzy and having a programmable msd or similar box between the coil an the dizzy to keep the injector timing set and still advance the timing , the msd box can do data logging aswell and is tunable from a normal laptop
theres an a14 efi manifold for sale on perth gumtree at the moment
Posted on: 2012/8/21 3:05
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Malaysia
Good idea to use msd to advance the ignition...
Posted on: 2012/8/21 7:48
From Nations Capital, Australia
Would you notice a big difference from batch firing as opposed to sequential on an A series?
Posted on: 2012/8/22 5:07
From Malaysia
for the sake of a little bit better FC i guess?
Posted on: 2012/8/22 10:18
From Malaysia
Anyone have the ECU wiring for a14e??
Isit similar to 200sx Ca20E???
Posted on: 2012/8/29 6:03
« 1 (2) 3 »
