Re: suggestions l20b or a15
L16 37kg lightweight block (L20b is 52kg, L18 44kg)
20mm shorter block (clears bonnet)
Longer L16 prepped conrods
Bore +2mm for 85mm
z20e pistons perfect
Modded L20B crank
1952cc and if not happy can be turboed
as an L16 for easy engineering
Easy for gearboxes ask Unfamilia
The 1.547 rod stroke ratio makes heaps of midrange torque and
will spool up turbos very early & no need to go over 7000rpm.
Posted on: 2012/8/30 13:17
Subject Poster Date
     suggestions l20b or a15 one20why 2012/8/30 11:02
       Re: suggestions l20b or a15 AndyM1 2012/8/30 11:43
         Re: suggestions l20b or a15 townie 2012/8/30 11:55
         Re: suggestions l20b or a15 Anonymous 2012/8/30 11:58
           Re: suggestions l20b or a15 Stock1200Ute1 2012/8/30 12:44
             Re: suggestions l20b or a15 D 2012/8/30 13:17
               Re: suggestions l20b or a15 PIGDOG 2012/8/30 15:40
                 Re: suggestions l20b or a15 Anonymous 2012/8/30 19:17
                   Re: suggestions l20b or a15 warner01 2012/8/30 19:44
       Re: suggestions l20b or a15 levey 2012/8/30 12:23
         Re: suggestions l20b or a15 Anonymous 2012/8/30 12:41
       Re: suggestions l20b or a15 dattoman_1000 2012/8/31 0:21
       Re: suggestions l20b or a15 bakat 2012/8/31 0:30
         Re: suggestions l20b or a15 Anonymous 2012/8/31 2:40
       Re: suggestions l20b or a15 Matto1kUte 2012/8/31 8:27
         Re: suggestions l20b or a15 loosekid 2012/8/31 8:42
       Re: suggestions l20b or a15 lamb_daiquiri 2012/8/31 9:23
         Re: suggestions l20b or a15 Anonymous 2012/8/31 9:55
       Re: suggestions l20b or a15 loosekid 2012/8/31 10:02
         Re: suggestions l20b or a15 Anonymous 2012/8/31 10:22
       Re: suggestions l20b or a15 AndyM1 2012/8/31 10:58
       Re: suggestions l20b or a15 D 2012/8/31 11:06
         Re: suggestions l20b or a15 1200rallycar 2012/8/31 12:36
           Re: suggestions l20b or a15 old-tin 2012/9/1 1:28
       Re: suggestions l20b or a15 one20why 2012/9/1 10:20
         Re: suggestions l20b or a15 Anonymous 2012/9/1 10:44
       Re: suggestions l20b or a15 one20why 2012/9/1 11:55
         Re: suggestions l20b or a15 warner01 2012/9/1 12:20
           Re: suggestions l20b or a15 Anonymous 2012/9/1 12:41
             Re: suggestions l20b or a15 D 2012/9/1 13:18
               Re: suggestions l20b or a15 Anonymous 2012/9/1 14:07
       Re: suggestions l20b or a15 one20why 2012/9/2 10:39
         Re: suggestions l20b or a15 D 2012/9/2 11:44
           Re: suggestions l20b or a15 warner01 2012/9/2 12:23
       Re: suggestions l20b or a15 elemental_funk 2012/9/2 15:19
         Re: suggestions l20b or a15 warner01 2012/9/2 17:48
           Re: suggestions l20b or a15 PIGDOG 2012/9/3 1:43
             Re: suggestions l20b or a15 PurpleJim 2012/9/3 6:30
