Browsing this Thread:
1 Anonymous Users
Water with Engine Oil |
From Colombo Sri Lanka
Hi all,
yesterday my little son accidentally added some water to engine (from opened oil cap). i think about 100 ml of water added to engine oil after that i started the engine it runs fine.
What should i do ? still i did not changed the oil
Posted on: 2012/9/13 5:59
Re: Water with Engine Oil |
On a long drive it may burn up like condensation but I'd drain the oil
Posted on: 2012/9/13 6:07
Thank you unfamilia,
I am not using my Datsun for long drive.
Can i remove oil nut and change the new oil or remove the sump ?
what is the better thing ?
Posted on: 2012/9/13 6:16
Just the sump plug. Drain and collect oil. And replace sump plug. Add new oil. If you really wanted to change the filter too.
Posted on: 2012/9/13 6:19
ok then i am not going to remove the sump. i will change the oil with filter
Thank you
Posted on: 2012/9/13 6:30
