Wanted 1200 diff
Wanted, we want to drop the rev's in our 1200 stock ute, I have read that an early model 4 speed bluebird 3.7 ratio diff is an option. Does anyone have one close to Canberra or any other suggestions? Thanks
Posted on: 2012/9/30 0:57
Re: Wanted 1200 diff
i believe the coupe diff is a 3.9 ratio?? Pre sure the ute diffs are 4.1
Posted on: 2012/9/30 2:03
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
From Geelong, Vic
what year is the ute?
if its an early one, i think 71-74/75 then it will have the smaller diff in it (same as other 1200 diffs) in which case the bluebird centre will not work
if its the later one, 75 onwards then a 4 door 4 speed series 1 bluebird should have the centre you are after. otherwise other series 1 and 2 bluebirds and jap assembled stanzas will have 3.9:1 ratio diffs that will do the job
Posted on: 2012/10/1 4:05
From Melbourne, Australia
arn't the blueys all H190?
he would be after a h165
Posted on: 2012/10/1 4:17
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Armidale N.S.W
Nah H190 is series 3 Series 1 and 2 had H165
Posted on: 2012/10/1 7:06
73 1200 wagon SOLD
I thought the same RC.
Never new that, you learn something new everyday!
Posted on: 2012/10/1 8:49
1200 Ute - Mild A12
Posted on: 2012/10/1 8:50
1200 Ute - Mild A12
Thanks guy's, you sure know your Datsun's..
The ute is an 81 model and it sounds as if I'm on the right track..
I just have to find one though.
Murray.
Posted on: 2012/10/2 13:15
From NSW, Australia
Murray keep us posted with how the revs go!! Im interested in changing the diff centre to cruise better on the freeway.
Posted on: 2012/10/3 1:00
Cheers,
Big D
Quadruple Crown in 1980, the year my 1200 was Built.
Id too be interested to see how you'd go with a 3.9 diff, im running my 4.1 with a mild a12 and 4 speed and sitting at around 100-110 km its revving at around the 3.5 grand mark.
Posted on: 2012/10/3 2:56
1200 Ute - Mild A12
