#1 i am after a door hinge 4 a 1200 coupe
_steve_ Posted on: 2004/4/12 10:49
right side
#2 Re: i am after a door hinge 4 a 1200 coupe
Dodgeman Posted on: 2004/4/12 11:58
Is your Nissan / Datsun dealer a no go?
#3 Re: i am after a door hinge 4 a 1200 coupe
who_your_datty_1200 Posted on: 2004/4/12 12:17
R the coupe door hinges the same as the sedans???? If they are I have some
#4 Re: i am after a door hinge 4 a 1200 coupe
ddgonzal Posted on: 2004/4/12 19:42
2 door sedan, 4 door sedan are identical, except for the bushings. A visual inspection may tell you how the bushings are different.
Part Numbers:
80400-H7000 HINGE ASS'Y-front door, upper (R.H from '72-6 replaces 80400-H1001)
80401-H7000 HINGE ASS'Y-front door, upper (L.H from '72-6 replaces 80401-H1001)
80402-H1001 HINGE ASS'Y-front door, lower (left and right are identical)
Hinge bushings
H0400-73001 BUSHING-door hinge (4 door sedan)
H0400-73002 BUSHING-door hinge (2 door sedan & coupe)
#5 Re: i am after a door hinge 4 a 1200 coupe
UTE18L Posted on: 2004/4/13 4:16
DD how bout the Ute?
Need right front if anyones got them.
#6 Re: i am after a door hinge 4 a 1200 coupe
ddgonzal Posted on: 2004/4/13 6:03
Ute should be same as 4-dr sedan front. The question is what year? Possibly the newer utes use a different hinge design?
#7 Re: i am after a door hinge 4 a 1200 coupe
UTE18L Posted on: 2004/4/13 9:39
Its a 1978, Aussie spec ute
#8 Re: i am after a door hinge 4 a 1200 coupe
ddgonzal Posted on: 2004/4/14 1:10
78 japan-spec ute uses the same part numbers.
#9 Re: i am after a door hinge 4 a 1200 coupe
UTE18L Posted on: 2004/4/14 6:01
Thanks Ddgonzal
#10 Re: i am after a door hinge 4 a 1200 coupe
enos1 Posted on: 2004/4/14 8:26
i have THREE, but i live in sacramento, california, .. ... ... i dont know if you want to ship that or not????
