Browsing this Thread:
1 Anonymous Users
Datsun 210 US L20B |
Quite a regular
Has anyone tried to put a L20B engine in a 210 US model car?Will it fit?
Posted on: 2001/9/10 10:51
Re: Datsun 210 US L20B |
From Wellington New Zealand
The L series engine was an option in Japan for the B110 & 210 .The 310 Sunny shares the same chassis dimensions as the Silvias and by using a Silvia crossmember an L series or FJ 20 will drop in. As has been said before look for a Auto trans model for the bigger tunnel in the B110 & 210 model range and the job is far easier. I used a cut and shut L series cross member to repower one of my 1200s. Weld some scrap angle iron across the L series mounts and cut them off the X member, then cut the A series off it's X member then weld the L series mounts onto the A series X member. Just tack weld it first then dummy up the engine to see if everything clears, sump etc. At this stage you can lower the height of the mounts to get the engine lower or further back. If done neatly the job can look factory and most people will never appreciate your work.
Posted on: 2001/9/11 4:57
