Re: Carbies
From Brisbane Qld
No its not a replace able One The exhaust shop put a bit of gue
on it Worked but I dident tighten it up after a few days like he asked
I do know that 1200,s u can replace but sunny,s u can,t.
Unless i could try to grind it of to Make it rounded of to fit new one???
Posted on: 2012/9/20 7:45
Re: Carbies
From Brisbane Qld
BUMP
Posted on: 2012/10/13 14:46
Re: Carbies
From Logan, QLD
Would you consider rewriting the first post so we can understand what you are asking?
Posted on: 2012/10/13 23:53
Re: Carbies
From Melbourne, Australia
seems like a simple situation to me
you have an exhaust leak, you tried to fix it the dodgey way. that didn't work
you have three options:
1. have an exhaust shop fabricate that flange section that seals to the manifold from new materials... may or may not work
2. get the after-manifold section from another car that is in better condition and have that cut in to your exhaust
3. get extractors and have them fitted
4. wait for little baby jesus to come perform a miracle and post a solution that won't cost you money
Posted on: 2012/10/14 1:05
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: Carbies
And if you don't believe in Jesus insert which ever religion or non denominational belief in its place.
Posted on: 2012/10/14 1:09
Re: Carbies
From Brisbane Qld
FLAT SPOT IS THE PROBLEM AND IN MY OLDER 1200 I HAD IN THE PAST THE EXHAUST DID LEAK BUT I NEVER HAD CARBIE TROUBLE. MABY BECAUSE IT ALL WAY RAN WELL BECAUSE MY PASSION FINGERS NEVER TOUCHED IT LOL.
Car seem,s to be ok know i have putin a Ocktaine Booster in it And went for a long drive
Its still has a bit of a flat spot but not as bad. This egine has done over 200thou as well
a littel smokey in 1&2Gears
Posted on: 2012/10/14 4:27
Re: Carbies
a common mistake is to assume an exhaust leak is not affecting how the motor is running
it certainly does, power drops, fuel consumption goes through the roof, idle gets higher and rough and you get flat spots
you will kick yourself for not doing it earlier the day you fix this exhaust leak, you have gone through 4 or more carbies trying to get it running right if memory serves me correctly
you will save the money you spend in fuel economy let alone the mental trauma you put yourself through
Posted on: 2012/10/14 5:43
1200 Coupe Rallycar
Re: Carbies
From Brisbane Qld
Yes thats the Right word,s METAL TRAUMA I have taken the car To the Exhaust shop the
Exhaust is fixed As good as it will get flage gasket. On my B310 1980 sunny The flage gasket
Is NOT A REMOVEABL gasket Like my 1200 was. And yes i have tightend all mainafold bolts pipes
Hose,s all that so i have been doing long drive,s and useing a octain booster and car will now do about allmost 380ks to a 30liter tank it it RUNS Better flat spot still there but not as bad. Could it be just #OOPS# fuel in QLD and Norther Nsw that i have been traveling To As far as Balina nsw
Posted on: 2012/10/15 2:45
« 1 (2)
