« 1 2 (3)
Re: Major Fuel Problem?
From Sydney
1200rallycar wrote:
in my experience this sort of thing is typical of weber carburettors, a full rebuilt and professionally tuned weber can only be expect to work well for 6 months before issues with gaskets, loose screws and jets, falling out of tune and cracked diaphragms.. had this many many times over the years
best option is the GX style SU's
Weber hater ha ha. From a Weber liker, all carbs require an element of maintenance from time to time. I fail to see how a change in fuel octane can result in the gasket being deformed, I guess it's possible, I would sooner believe the gasket failure was a result of ethanol content though. Either way I would suggest the poor ecomomy is due to the faulty gasket, incorrect jet selection and maybe the timing is not set to optimum. Worth also checking the distributor internals for correct functionality, i.e bob weights on the mechanical advance, dwell angle on the points and the vacuum advance diaphram on the side of the distributor.
Lastly, to take advance of high octance fuel in NA applications, you need to up the cylinder compression ratio.
Posted on: 2012/10/25 0:32
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From Leeton NSW
The Carby has only done about 3000km so its basically new i bought it brand new from weber so yeh im just using the jets that i was supplied with im pretty sure there too big but i was going to leave them as im thinking of putting a cam in so yehh..The gasket was sucked in due to the backfiring apparently.. and i have electronic distributor which has been professionally fitted by a mechanic that knows what hes doing as hes been in the business for over 30 years and after all the recent mods it was tuned by the same mechanic running absolute perfect not even a misfire only abit lumpy on idle but no stalling..
Posted on: 2012/10/25 0:47
From Sydney
Still has the standard camshaft? If so, it should not be idling lumpy, idle jet is too big [Idle jet also meters fuel for progression cct also]. jets are approx $6 - $10 online. Is the bridge still in the factory inlet manifold? the weber adaptor is mounted just on top. It is worth removing the bridge area to improve the flow characteristics. When you say backfire, do you mean the carb is coughing? unlike backfire out the exhaust. If so, it suggests a lean mixture condition is occuring, probably when the secondary throat throttle plate is opening, combined with no fuel.
Posted on: 2012/10/25 0:56
Edited by benny on 2012/10/25 1:37:06
1970 KB10 Coupe
S13 caliper b...
From Leeton NSW
yehh still has standard cam yehh its idiling lumpy because the jets are to big i know that but im unsure of what jets to get..yeh im unsure about the bridge actually..naa not out of the carby coming out of the exhaust only when you are coming back down through the gears and its bad backfire to and real rumbly, its also hard to start and almost undriveable in first gear it will be good for a few seconds then just bog down then you have put the clutch it give it a rev then go again
Posted on: 2012/10/25 1:05
From Sydney
The idle jet on the 32/36's are easy to get to. They are located on the side, there is a brass cover screw/holder covering the jet. Identify what you have currently installed. At a guess im going with 55 /60 being stamped on the jet. 40 /45 is probably more in the zone. An air /fuel ratio gauge would be the only real way of knowing if the mixture is on the money. U-ego make a cool digital one which uses a bosch wide band o2 sensor that needs to fitted to your exhaust, or pay for some dyno time. Maybe you mechanic has a gas analyser.
Posted on: 2012/10/25 1:44
1970 KB10 Coupe
S13 caliper b...
From Leeton NSW
heyy guys just letting you's know that there wasnt much even wrong i got my brother to look at it the other day and we noticed the choke butterflies on top of the carbies were seized for some reason so we fixed that and now its running like a dream again haha thanks for all the help..
Posted on: 2012/10/28 7:06
Glad to hear the problem was found.
Btw, a new Weber 32/36 setup for L-series, runs perfectly fine on stock A12 to stock L20B. Not with optimum fuel economy, but will idle, accelerate and cruise without any noticeable problems. You still have to set the idle speed and idle mixture, but you don't have to change the jets.
Posted on: 2012/10/29 1:32
« 1 2 (3)
