#11 Re: A15TT LIVES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
dattodude Posted on: 2004/4/14 7:41
Just pull it off enough to put "a little" exhaust putty in the leaking area.
Sounds bodgey, but it'll probably work for 6-12 months. You can save up to do the job properly in the meantime.
After making the Turbo manifold, did you get it heat treated and remachined flat?
You have to do that if you expect it to stay square. I expect that the first few hard runs warped the manifold enough to break the gasket seal.
If you do take the custom exhaust manifold off, run a straight edge over it, I think you'll find it's no longer flat across the mating surface.
Chris
#12 Re: A15TT LIVES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
1200rallycar Posted on: 2004/4/14 7:52
ah bugger
thanks for the tip
#13 Re: A15TT LIVES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
pro-240c Posted on: 2004/4/14 9:04
i believe the great debate was that epic of a thread about a whole lotta nothing. something to do with it not working, lots of surging etc.
i'd sure like to see the doubters with their feet in their mouths now, and to refrain from posting about something they have little experience with.
anyway, glad to see how strong it is.
what turbos are they? IHI RHB4's?
#14 Re: A15TT LIVES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
1200rallycar Posted on: 2004/4/14 10:11
they are diahatsu diesel 1000cc turbos (made by AISIN)
im getting my mechanic to look into a diffrent type of manifold gasket, or maybe seperating exhuast and inlet manifolds, i suspect now after talking to my mechanic that the gasket i have been using is not really suited to extractors and the like
what are other people using for manifold gaskets????
#15 Re: A15TT LIVES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
feral Posted on: 2004/4/14 13:41
I ended up getting some double steel faced gaskets made up for my FIA head as the available gasket were crap. Cost $100 each but are semi reuseable.
#16 Re: A15TT LIVES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
pro-240c Posted on: 2004/4/15 3:02
i use CAT diesel gasket compound.
that sh1t NEVER leaks.
#17 Re: A15TT LIVES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
A14force Posted on: 2004/4/15 9:23
Congrats, I am extreemly pleased to hear it. Sort out the teething problems, and find out what ET she can do.
#18 Re: A15TT LIVES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
thebuzz Posted on: 2004/4/15 9:32
sounds like an interesting setup mate, well done!
what sort of power figures are you looking at?
#19 Re: A15TT LIVES!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
1200rallycar Posted on: 2004/4/15 14:38
haha love the sunvisor in the avatar "thebuzz", very sleeperesque
dunno what power to expect, mechanic has dyno though just have to fire him up on the idea of strapping it on for me, if he has it properly calibrated now (not long installed)
the mechanic is searching for an exhuast gasket for me and also is gonna clean out the carb to hopefully help with fuel probs, but im thinking it may just need bigger jets
« 1 (2)
