« 1 (2)
Re: Front End bits
From Goulburn NSW
Hi guys when u turn the steering does the shock rotate to.
Posted on: 2012/10/30 6:35
Re: Front End bits
From Geelong, Vic
yes
Posted on: 2012/10/30 7:29
Re: Front End bits
From Geelong, Vic
well it depends which bit i guess, the main body of the insert rotates with the strut housing, the shocks rod/piston will not rotate as it is solidly located in the strut top which is bolted to the body
so the bit you can see wont rotate
Posted on: 2012/10/30 7:31
Re: Front End bits
Well depends on the setup as well
Posted on: 2012/10/30 7:58
Car free
Re: Front End bits
From Goulburn NSW
Hi guys which way does the cross member go?the side closest to the tranmission bracket to the front.
jpg  thumbMD001.jpg (2.61 KB)
14333_508f88c8f1872.jpg 101X66 px
Posted on: 2012/10/30 8:00
Re: Front End bits
The cutout in the gear box cross member goes on the pass side of the car
Posted on: 2012/10/30 8:02
Car free
Re: Front End bits
From Goulburn NSW
Hey Nick im talking about the engine cross member,does the bow go to the front or back.
jpg  thumbMD001.jpg (7.19 KB)
14333_508f8c3e1c57b.jpg 202X132 px
Posted on: 2012/10/30 8:13
Re: Front End bits
Where your arrow is goes toward the rear of car
Posted on: 2012/10/30 8:45
Car free
Re: Front End bits
From Goulburn NSW
Ok guys theses are the LCA's i will be getting when i buy the maddat conversion kit.What i dont understand is how are the caster bars going to bolt to the LCA flush,because they are recessed on both sides.Has anyone used thesed that can explain how it will work.
jpg  thumbLCA1200B.jpg (18.09 KB)
14333_509385e1a280d.jpg 101X65 px
Posted on: 2012/11/2 8:35
Re: Front End bits
At a guess the ball joint bolts to the top and makes the top flush, y not ring Scott he will help out
Posted on: 2012/11/2 9:15
Car free
« 1 (2)
