spec's; a15 1526cc.
block bored 1mm
decked block
cam bearings fitted
reground crank
close/honed rods
new cast pistons/rings(fly cuts for cam)
bearings
gaskets
cam 252duro at 0.050/0.300 lift
new timing gear set/dailed in cam
head has big port job/big valves 40/32/double springs
rocker shaft spacers.
new water pump.
11:1 comp ratio
welsh plugs/paint/plugs/oil/filter/test run.(re-toqued head & tappets done)
twin 40mm dellorto's & manifold,linkages, new sock air filters/ new 4 into 1 extractors / electronic pulsar dizy,
all complete & ready for someone to bolt in.
and whatever i forgot
u guys can add it up on pricing im sure.
SOLD
