Re: GA16DE transmission adapter
From Brisbane
If anybody is reading this with GA16 motor and is looking for a some head parts I have some I won't be using and are for sale.
- Full overhauled head which has been ported an polished for racing.
- A pair of brand new cast cams, ground for racing, same profile as was run in the turbo Sierra's, it's hard to get a good cam profile because of the small buckets that the GA heads use.
- A new twin weber sidedraft manifold for the GA head, good for weber style TB's.
PM me if you want any further info.
If you did decide to use a GA motor, couldn't you remove the dizzy (so you don't have to cut a hole in your firewall) and use a crank angle sensor?
Posted on: 2012/9/10 7:16
From Townsville
You got any of the GA16 head parts left?
Posted on: 2012/11/13 6:33
« 1 (2)
