« 1 (2)
Re: Spark from coil, but not from distributor. Any advice?
So be sure to connect both wires from the 1200 harness to the coil+ terminal. These are the two wires that connected to the ballast resistor
So this is not how it's supposed to be?
I tried that Benny but no win, no spark at all now Will get out with the test lamp and if the ignition is circuit is faulty I'll bridge the ignition (as Dylan suggested) and see if there is any success then.
I really need to improve my understanding of electrics, totally flying blind here
Posted on: 2012/11/13 6:53
From Sydney
Also check the clearance between the pertronix module and the pickup magnet(s) that sits under the rotor button. As close as possible, but not touching. maybe the issue is that the pertronix unit is not triggering...
Posted on: 2012/11/13 7:14
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
« 1 (2)
