Fitting an L20 under the bonnet
From Melbourne, Aus.
Posted on: 2012/11/18 9:24
Edited by crumb on 2015/1/22 21:48:34
Re: Fitting an L20 under the bonnet
From Sydney, Australia
Apparently you need to use a different sump (and oil pickup) to be able to mount the L20 low enough.
Posted on: 2012/11/18 10:55
You need a bluebird front sump l20b. You really need it to sit as low as possible to fit l20 over l16/18 due to extra 20mm deck height.
Yours engineered?
My sump and pick up were modded to fit lower into the bay too but then.draglink clearance can become an issue at full lock
Posted on: 2012/11/18 11:24
Posted on: 2012/11/18 11:47
Edited by crumb on 2015/1/22 21:48:46
Don't know, never had a gx bonnet. You going all Jap day this Sunday?
Posted on: 2012/11/18 19:44
The frame of the gx is the same it's only the skin that's a different shape but correct me the clearance you need from the l20 is toward the front of the motor anyways
Posted on: 2012/11/18 20:24
Car free
Your correct fatto
Posted on: 2012/11/18 21:04
That's right, the 1972 bonnet for DX/GL/GX doesn't have any additional clearance. It is strictly for looks.
L20B is 19.6 mm taller than L16. It will fit under stock hood if:
* use 910 Bluebird front sump and oil pick
* place engine as far back as possible 10mm clearance to firewall
* mount almost down to the crossmember maybe 3mm clearance
* don't weld the mount plates too high up
* Use the lowest profile rubber isolators (early 510 are shorter than A-series)
* Use stock air cleaner, or a 32/36 with thinnest adapter, or a low profile aftermarket filter
And remember to lower transmission too to achive the standard 5-degree powertrain slope of the 1200, so that the diff pinion is in alignment.
Posted on: 2012/11/19 3:58
Posted on: 2012/11/19 10:57
Edited by crumb on 2015/1/22 21:49:04
Put up some pics. Even though pig dog did my x member etc I have some knowledge. Datsandy does too.
Is your car engineered? is it driveable? I will he at all Jap day Sunday come say hi
Posted on: 2012/11/19 12:03
