#1 Urgent help
darrenwilson Posted on: 2012/12/12 2:18
i have s13 brake modification complete i followed all the steps but my 13'' wheels wont fit.What should i do?
#2 Re: Urgent help
1200rallycar Posted on: 2012/12/12 2:28
explain why they don't fit (hitting in the diameter or on the front face) and if you are using steel or alloy wheels, it's not uncommon to gring some material off the back of the caliper to make clearance
#3 Re: Urgent help
Posted on: 2012/12/12 2:45
Even better are they 250 or 280mm rotors. The larger won't fit under 13's
He uses 13 inch super light style rims rc
#4 Re: Urgent help
darrenwilson Posted on: 2012/12/12 3:17
Thanks for the feedback guys,i have longer studs to install so when im done i will know better.
#5 Re: Urgent help
darrenwilson Posted on: 2012/12/12 23:27
I i fit spacers will it help it form hitting the front of the caliper?
#6 Re: Urgent help
ddgonzal Posted on: 2012/12/13 1:10
We don't know. 13" wheels are all shaped a little differently. S13s used larger wheels.
#7 Re: Urgent help
Posted on: 2012/12/13 1:37
take some pictures of where its hitting. Spacers may move the inner welds or lip of the rim further away from the calipers. It depends on manufacture and offset of rim.
see how on the inside the rim tapers towards the face of the wheel
#8 Re: Urgent help
spatchcock Posted on: 2012/12/13 4:59
Hey hey
In having the same problem.
Just mocked together the brakes on some spare struts to see if they would fit over my newly acquired ssr mk's 13x7j
The hit on the caliper on the following place. I chalked them to find out. I'm planning in running a small spacer but filing the caliper did come to mind
#9 Re: Urgent help
supafatto Posted on: 2012/12/13 5:53
My rx7 stuff has been shaved down to fit 14's over them, you are able to take a small amount off of the callipers and as people have said it depends on wheel style and offset
#10 Re: Urgent help
darrenwilson Posted on: 2012/12/16 3:18
My problem is that i have found out that i have the wrong s13 disc.I need the smaller ones..
I have also reverted to my original b310 setup today.im rooling for the while now.
