datsun panel removal from wreckers?
From vic
hi just wandering if anyone has tips on how to remove a datsun 120y boot floor along with rear panel that has tailights on it.
obviously you cant use electrical tools like angle grinder so how would i go by romoving them as its all spot welded in.
drilling each spot weld would take to long because you then have to seperate the two pieces?
any ideas would be appreciated
also if anyone has a 120y they are wreking with these parts rust free let me no.
Thanks!
Posted on: 2012/12/12 7:03
Re: datsun panel removal from wreckers?
Hack saw and tin snips? Would take ages still. Will they let you take battery powered tools. You Can get 12 and 24v angle grinders
Posted on: 2012/12/12 7:07
I would use a battery operated angle grinder jut chop 30mm more then what you have to then trim to suit when you get home
Posted on: 2012/12/12 7:14
datsun a15 ute
From Adelaide
Surely the wrecking yard has gas cutting available? Ask them to cut out the bit you want.
Posted on: 2012/12/12 8:10
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
From Coondle, WA Australia
if all else fails, you can buy a cheap generator that would be good enough for an angle grinder for about $100. 2400W GMC from Big W should cover it just.
Posted on: 2012/12/13 21:43
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
