« 1 ... 12 13 14 (15) 16 17 18 ... 20 »
Re: rocketrod's 1200
From Nyngan, nsw Australia
comes out along side the ignitor plugs loom (green & brown) wires, maybe sumthing to do with vacuum,
whats that part that bolts beside the ignitor?
Posted on: 2012/11/21 3:14
living is good,.....
From Brisbane
The boost control solenoid mounts next to the ignitor. I had it remove from my loom but I can check my spare over the next few days.
Posted on: 2012/11/21 6:30
You think il need it, will it run without it
Posted on: 2012/11/21 12:07
From Brisbane
It will run without it and if you wanted to add a boost contorller or simple boost 'T' you need to remove it anyway. I read that it is meant to help with boost response.
Posted on: 2012/11/22 2:31
thank you i appreciate your help, is there any visual information i cant find to see where its router-ed to..
Posted on: 2012/11/22 3:14
From Brisbane
No problem mate.
I double checked and it is for the factory boost control solenoid. I have attach a photo below showing the electrical connections joined. This link shows the vacuum piping layout should you decide to use the boost control solenoid. http://www.impactblue.org/content/dis ... chtype=section&search=223
There are plently of other diagrams on that site - just select the section list option at the top.
jpg  IMG_0696a.jpg (181.93 KB)
7166_50b1d91cd3d3e.jpg 800X598 px
Posted on: 2012/11/25 8:40
yeah great, that a pretty detailed diagram..cheers, just a few odds'n'ends to tidy up now i know what they do
is like to drop the rear down abit more sits a tad to high, i recall there a few lads had the leaf ends turned down, any suspension place can do or is it specialized job...
Posted on: 2012/11/25 12:58
picture illustrate the ride height i like.....
Posted on: 2012/11/25 13:04
picked up seats today matey done a bloody good job...problem i have now is ive lost 2 chrome seat Phillips/bolts, any you fellas have a couple spare i could have so i can put them together...please!!!
need 2 of these
Posted on: 2012/12/12 10:16
for sure fellas there be some of you that have a couple bugged seats or just one that has two bolts that can part with, i don't mind shedding a couple coinss
Posted on: 2012/12/13 22:07
