Browsing this Thread:
1 Anonymous Users
Re: pertronix kit good? how to install with resistor |
From Sydney, NSW
Thanks DD I have a mid mounted distributor on my engine at the moment so I guess it makes the swap easier!
Thank you again for taking the time to help..
Would you happen to have a part number for a coil that would suit if I wanted to remove my resistor?
Posted on: 2012/12/14 0:58
Edited by thomen on 2012/12/14 1:31:09
From Sydney, NSW
would this coil be the right 12v no ballast resistor high output coil? Bosch HEC715
Cheers, Tom
Posted on: 2012/12/14 3:01
Edited by thomen on 2012/12/14 4:05:25
From Sydney, NSW
would this be the setup I'd need to buy to get it all sorted? Cheers, Tom
Posted on: 2012/12/14 4:22
Registered Users Contentmaster Usermaster
Yes, also need the Rotor. You can buy Cap, Rotor and Coil in Australia. Cap & Rotor is the same as points distributor late 70s/early 80s for nearly all Datsuns. Coil from early Pulsar will work.
Cap & rotor set: Bosch 06054 Cap: Bosch 03107 Rotor: Bosch 04095 Coil: Bosch 00200, Nissan 22433-H7280, Hanshin CIT-30, Hitachi STC-30
I would not use Bosch HEC715, it draws more current than the specified high-energy Bosch 00200 coil.
And keep in mind that sometimes you get a bad part from the parts store, but they do guarantee returns.
Did you get my PM?
Posted on: 2012/12/14 7:53
From Sydney, NSW
Thanks so so much for all of this.. I contacted Bosch and try never heard of the Bosch coil part number.. will check my pm now!
Posted on: 2012/12/14 7:57
From Sydney, NSW
Pm sent. Thank you
So in the wiki on the b310 conversion it mentions a condenser.. what part number is that?
Posted on: 2012/12/14 13:36
Edited by thomen on 2012/12/15 8:33:45
