#1 After a complete stop Need Higher accelaration to move the car
Sumith Posted on: 2012/12/18 14:31
Hi Guys
I have corrected my carburetor issue 90% .So the car goes normal pulling well and idles smooth and doesn't die in idle ,but only after a complete stop i can't get it running unless i press the accelerate a higher rpm ,if not it tries to kill the engine only problem is that i have now.is it a symptom of lean air fuel mixture ?
and again float level is perfect.
thanks
regards
sumith
#2 Re: After a complete stop Need Higher accelaration to move the car
thaifrog Posted on: 2012/12/18 15:13
Hi Sumith,
is your carb getting hot ? if you stop the car then have trouble getting it going it could be vapor lock... basically the fuel gets that hot that it boils in the carb.
i had this on my A14 engine and had to wrap the exhaust manifold and install a heat shield...
#3 Re: After a complete stop Need Higher accelaration to move the car
ddgonzal Posted on: 2012/12/19 0:57
By 'complete stop' do you mean turning off the engine? When re-starting a warm engine it is normal to hold throttle open part way - press accelerator pedal about 1/2 way down.
#4 Re: After a complete stop Need Higher accelaration to move the car
Sumith Posted on: 2012/12/19 5:07
Hi DD
No While engine running only,if you stop the car a traffic or some reason, i can't get it running as usual need to accelerate moderately higher than usual if not engine tries to stall, while running normal speed no problem.
Here i pulled a spark plug again and noticed it is little white color means too lean is it ?
and confirm me this too
Slow air bleed primary jet is much bigger than secondary is it ?
jpg  plug.jpg (67.20 KB)
10994_50d14b73ee542.jpg 480X640 px
#5 Re: After a complete stop Need Higher accelaration to move the car
ddgonzal Posted on: 2012/12/19 6:57
That looks too rich. The part where the color matters is deep down inside at the base of the insulator. You can get some idea by looking at the ring at the end of the threads.
To tell by the color, warm up the car, drive it as per normal and come to an idling stop. The cut the engine and look at the plugs. Because if you accelerate the car again, the color will change, so the color needs to be checked at the moment of problem.
Tendency to stall from a stop is usually caused by one of these:
* Accelerator pump problem
or
* Vacuum Leak
or
* Bad coil
Occasional a coil will work fine at higher RPM but not at low RPM
To test for Accelerator pump trouble, while car is moving, let engine idle (depress clutch) for a while, then let out clutch and try to accelerate from idling RPM. If it is fine, chances are it is not the accelerator pump. You can also test the pump with a visual test.
Test the coil by swapping it with another unit, for example the one in your other Datsun.
#6 Re: After a complete stop Need Higher accelaration to move the car
Sumith Posted on: 2012/12/19 7:08
Hi DD
ok i will try it back again and let you guys know,
thanks
regards
sumith
#7 Re: After a complete stop Need Higher accelaration to move the car
Sumith Posted on: 2012/12/19 7:12
Hi DD
Do you think How long do i need to run the car to check the status of spark plug ?are 2 to 3 kms ok or need more, i am running 82C thermostat on it
thanks
regards
sumith
#8 Re: After a complete stop Need Higher accelaration to move the car
ddgonzal Posted on: 2012/12/19 7:30
You need to run it as long as necessary to re-create the problem condition. That might be 30 seconds, or it might be 10 minutes.
confirm me this too
Take a look at the Jetting Specifications.
#9 Re: After a complete stop Need Higher accelaration to move the car
dattodude Posted on: 2012/12/19 11:31
Car stalling at max vaccuum under brakes, may be booster related?
#10 Re: After a complete stop Need Higher accelaration to move the car
Sumith Posted on: 2012/12/24 8:59
Hi guys
I got it running almost ok,i went around 100 KM journey up and down and pulled spark plug and it was ok felt it was little lean and adjusted the mixture little rich , now it is perfect no considerable miss on law acceleration and pulls well,it is ready for x mas cruise starting from tomorrow early morning as usual.
thanks
regards
sumith
jpg  Plug.jpg (63.42 KB)
10994_50d8193e70934.jpg 640X480 px
