« 1 (2) 3 4 »
Re: Ca Plenum Questions.
i just sourced a euro head and manifold
Posted on: 2012/12/18 1:14
From Goulburn NSW
How much did that set u back bailz?they are 4 port arent they.
Posted on: 2012/12/18 1:16
The CA cossy head :) usually from OS so have to factor freight.
I have one without cams but bought Japanese HKS cams for it.
Also chopped the primary manifold as its severely restrictive
for the size of the inlet ports. Mine was getting custom runners
to suit the ports and equal length plenum design.
Each port is like 56mm wide and 48mm tall massive to suit short
stroke ratio design and boost but mani runners are bottlenecks.
Posted on: 2012/12/18 1:38
i got it with a spare ca18det that I bought....didnt realise until I pulled it down that it has 4 ports instead of 8
Posted on: 2012/12/18 4:34
Thats 700-800 dollar reasons to celebrate great score!
The cosworth of Nissan heads for free gotta love that.
Posted on: 2012/12/18 8:07
From Brisbane
design like this d? I still like the 8 port better
jpg  aaaa.jpg (105.41 KB)
13026_50d0444e36ed7.jpg 407X569 px
Posted on: 2012/12/18 10:24
X-sactly that kind of split plenum but the Toyota Beams Yamaha headed 3SGE is the best Ive seen as it has no sharp edges.
4 ports all the way! 8 ports where tried and left behind.
Posted on: 2012/12/18 12:37
From Goulburn NSW
Hi guys i know this is a stupid ? but is their a gasket between the mani and head.
Posted on: 2012/12/21 6:19
Yes, 4 ports are better for full-throttle, high RPM use. Makes a bit more top-end power.
But the 8 port manifolds actually make a lot more torque below 2000 RPM (about 1/3 more power), and are very close to the same top-end power.
Posted on: 2012/12/21 6:46
From Christchurch NZ
With a redline of say 8K for a worked motor, and a turbo that spools at say 3k, you're going to be using that extra bottom end that the eight port head gives in 1st gear only. In a hard launch you'd be above 2k anyway, so I say four port all the way!
(Only because I have one of course! hahaha)
Posted on: 2012/12/22 4:53
Forced Induction!
« 1 (2) 3 4 »
