Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#21
Re: Ca Plenum Questions.
mcdat
Posted on: 2012/12/22 5:10
Hi guys this is what im planning to get done convert the 8 port into 4 port but am worried that the gasket is going to get in the road and restrict flow.The gasket will be slightly moded.Anyway this is the head after being converted.Im begining to think that a standard 4 port head will be better as i have the opertunity to buy one.
#22
oda70
Posted on: 2012/12/22 5:27
just buy some new gasket 1mx1metre and cut your own gasket to size
#24
Hyperslide
Posted on: 2012/12/22 6:56
Supercheap, Repco, Autobarn. Any auto parts supplier has rolls of gasket paper in different thicknesses.
#25
mcdat
Posted on: 2012/12/22 7:37
Thanks mate,what thickness should i be looking at
#26
tappet
Posted on: 2012/12/22 23:09
Ive got a 4 port head in brisbane if anyone is interested.
#27
mcdat
Posted on: 2012/12/23 3:04
Hi guys im going to make a custom gasket,what thickness should i be looking at.Im going to get a stock 8 port gasket,draw it onto the gasket paper then do the mods then cut it out.If i get a mtr then i will have plenty if i mess it up.So what thickness 3mm.
#28
D
Posted on: 2012/12/23 22:54
funny that but true the 4 port is the choice for even the similar RB engines for a good reason. The 8 ports have more low end turbulence which only is good with the extra butterfly setup and for NA only. For boost 4 ports all the way.
http://www.lewisengines.com.au/category25_1.htm 1200aud for ported 8 port might as well go 4 ports right up
#29
mcdat
Posted on: 2012/12/26 3:58
Hi guys i need ppl's expert opinion on what i want to do or should do,will an 8 port head converted into a 4 port have better characteristics than a standard euro 4 port as the port will be much bigger than the euro 4 port.Is there such thing as going to big?
#30
D
Posted on: 2012/12/26 15:55
8 port is enough for most people as spending 1200 on making an 8 port to a 4 port is quite pricey. Also if bigger was better then even toyota 4age would have stayed with their big port head but went smaller. With boost the 8 port is more than fine just needs some good match porting and secondary butterflys removed, tigged smoothed out etc.
What are you after in terms of performance? a stock ca18det is capable of 200hp atw without too much effort. You can view topic.
