Re: for sale nissan 1400 with lexus v8
Posted on: 2013/1/3 6:30
We get these motors easily in aus 2nd hand. Great 4lt v8. Respond well to boost via turbo or super chargers.
Shame is we can't engineering here possibly now.
He got extra space by mounting rad forward of the rad support panel. Not a great solution if he gets a love tap from a reversing toe ball
Posted on: 2013/1/3 9:48
quad cam v8 in an early cedric alot of work so this ute is an amazing effort for sure just for an idea of the work
http://ozdat.com/forum/viewtopic.php? ... ilit=engine+sump&start=45
quad cam vs pushrods, give me a compact pushrod v8 anyday
jpg  modern quadcam vs pushrods.jpg (39.02 KB)
737_50e565f590b7e.jpg 520X198 px
Posted on: 2013/1/3 10:59
From Geelong, Vic
bit of an unfair comparison their D, the nissan quad cams and stupidly big compared to the toyota V8s. my brother has a 1UZ sitting in a ke26 at the moment....they arent that hard to fit. just really long coz they have all the accesories mounted infront of the engine and 2 dizzys sticking out the front of them
Posted on: 2013/1/12 6:21
Mik loves compact push rods too! :)
Posted on: 2013/1/12 6:38
Unfair comparo? definitely not quad cam v8s are huge complicated, centre of gravity higher and heavier
Also have a look at the perfect nissan silvia engine :)
jpg  1uzvsls1.jpg (48.78 KB)
737_50f131338a07a.jpg 600X345 px
Posted on: 2013/1/12 9:46
Love this comment by ottopilot on ft86club:
Yup. I'm not averse to any engine architecture that gives me the power I want for as little weight as possible. The LS V8 does lend itself to being swapped into smaller/lighter-weight cars much more readily than physically bigger DOHC V-engines. And thanks to Camaro SS sales (nothing but donor cars to me!), there will be a good supply of LS3s and T6060 transmissions for some time to come
I think a corolla with 1uzfe is great combo but a 1200 ute would be far better off with a Y44 nissan v8 found one at ekw for $1200 when they where available there some years ago.
In reality here is where a chevy v8 should belong in :)
http://www.ft86club.com/forums/showpost.php?p=573324&postcount=57
Posted on: 2013/1/12 9:58
From Geelong, Vic
i was meaning using the nissan v8 to show the size of a quad cam v8.....the nissan engine would make a 1uz look small also
and im pretty sure once you add the manifolds to the LS they end up being nearly as wide as a 1uz, and they are also almost the same height and length. They just look smaller, especially when the one in the pic has no accesories
Posted on: 2013/1/12 11:58
no the ls1 is smaller there is no optical illusion the in manifolds are all there on the pic both missing ex manis.
Yep but the quad cam v8 in pic is close to the nissan chain vh series yep 1uz is smaller but I think its longer. Nissan v8 chain driven no belts to bother about, VK series even smaller.
VH45: 710 + 800 +640 = 2150 cm
1UZFE: 660 + 700 + 710 = 2070 cm
Posted on: 2013/1/12 13:13
« 1 (2)
