#21 Re: GX Bonnet, 63A, LSD, Stainless ex, big port H89, and stroker crank
D Posted on: 2013/1/5 3:17
There is a fair amount of work both to e16 crank and block to make it all fit most people even if they know the secrets still have to get the work done by someone with the same enthusiasm as ive found some places just dont give a toss in favor of the common bogon engines. The a15 strokers I was referring to went for 40mm journals and nitrided due to machining them down to that size. FCW e16 crank is a treat and looks good on that pic whats the cost?
#22 Re: GX Bonnet, 63A, LSD, Stainless ex, big port H89, and stroker crank
ddgonzal Posted on: 2013/1/5 3:27
>> 88mm counterweight A series crank shaft needs to be balanced - $1600
#23 Re: GX Bonnet, 63A, LSD, Stainless ex, big port H89, and stroker crank
D Posted on: 2013/1/5 3:33
Thanks DD missed that a bit unbalanced in my reading
#24 Re: GX Bonnet, 63A, LSD, Stainless ex, big port H89, and stroker crank
2QK4U Posted on: 2013/1/14 9:41
LSD is sold
#25 Re: GX Bonnet, 63A, LSD, Stainless ex, big port H89, and stroker crank
ruredi Posted on: 2013/1/19 4:33
PM Sent.
#26 Re: GX Bonnet, 63A, LSD, Stainless ex, big port H89, and stroker crank
yfj20t Posted on: 2013/3/10 19:33
do you still have the bonnet
#27 Re: GX Bonnet,Stainless exh, stroker, yella terra
2QK4U Posted on: 2015/3/8 11:28
yep still have the bonnet.
#28 Re: GX Bonnet,Stainless exh, stroker, yella terra
crumb Posted on: 2015/3/9 10:33
What condition is it in?
Do you have a photo of it?
#29 Re: GX Bonnet,Stainless exh, stroker, yella terra
ruredi Posted on: 2015/3/17 7:14
+1 interested in the bonnet. Please reply to PM.
#30 Re: GX Bonnet,Stainless exh, stroker, yella terra
2QK4U Posted on: 2015/7/27 3:42
Bump
« 1 2 (3) 4 »
