(1) 2 3 4 5 »
#1 How to Install Break Master Under dash ...ideas ?
CrazyHawaiian Posted on: 2013/1/14 20:31
I need ideas on how to go about moving break master under dash to fit dual carbs???
I have a few ideas but just puttin it out there.Need pic's of push linkage.
and if someone has a manifold for a single DCOE that fits A14 H89 head would be even better.
#2 Re: How to move motor over ...ideas ?
clyons8 Posted on: 2013/1/14 20:55
Remote or under dash master cylinder?
#3 Re: How to move motor over ...ideas ?
1200rallycar Posted on: 2013/1/14 20:56
there is many different height engine-side metal mounts, perhaps you can switch to another to drop the correct side of the motor
please tell us what car/year and if the motor is early or late series
plus you can buy shorter engine mount rubbers from other cars to lower one side also
#4 Re: How to move motor over ...ideas ?
ddgonzal Posted on: 2013/1/14 21:54
#5 Re: How to move motor over ...ideas ?
CrazyHawaiian Posted on: 2013/1/14 22:41
Also I have the early A12 72' coupe.
can't go any lower cause of the oil pan ..so what about going up a little and to the right a bit?
How much work goes into putting master under the dash?
#6 Re: How to move motor over ...ideas ?
D Posted on: 2013/1/14 23:02
it is some work for under dash BM but way worthwhile and only a tad more than tilting and engine with custom mounts.
Tommoz had a good guide with pics how to do it using remote bmw fillers but I cant find the pages from his build they where very detailed.
#7 Re: How to move motor over ...ideas ?
ddgonzal Posted on: 2013/1/15 2:15
If you move the engine over, you also need to move the transmission over. I have never heard of anyone doing it.
#8 Re: How to move motor over ...ideas ?
CrazyHawaiian Posted on: 2013/1/15 3:50
Well I guess I need to put it under the dash ,I would rather have my motor strait.
How long should this job take?
#9 Re: How to move motor over ...ideas ?
Posted on: 2013/1/15 3:51
Depends if you have all the parts already. But allow a day
#10 Re: How to move motor over ...ideas ?
ddgonzal Posted on: 2013/1/15 5:15
What not put the factory Twin Carb setup on? It fits on LHD cars.
(1) 2 3 4 5 »
