Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
Burning fuse on ignition(reds)
uteboy1200
Posted on: 2013/1/15 3:26
My 1200 ute was running fine then today it wouldn't start. I noticed the transistor connected to the coil was getting hot. checked the coil setup and fixed. Still burning meter reg fuse. what to do?
#2
Re: Burning fuse on ignition(reds)
Posted on: 2013/1/15 4:19
Transistor on the coil? That is not stock.
#3
Posted on: 2013/1/15 4:22
What to do? Read this: Blown Fuse
#4
uteboy1200
Posted on: 2013/1/15 4:50
Sorry mate, its the 'resistor' connected to the coil (white rectangular box). Is it okay to bypass this to test if it will blow the fuse when ignition is turned to on?
#5
Posted on: 2013/1/15 5:14
You can bypass it for about 30 seconds.
#6
uteboy1200
Posted on: 2013/1/15 5:26
Thanks ddgonzal, i'll check the wiring diagram and chase down the problem. Cheers for the quick replies
