WHATS THE DEAL WITH A15 FROM VANETTE?
Quite a regular
From MELBOURNE, VICTORIA AUSTRALIA
WHATS THE DEAL?
IF I BUY A NISSAN VANETTE SMASHED HARD IN THE REAR FOR CHEAP, CAN I BOLT THE ENGINE STRAIGHT IN MY 1200 UTE OR WHAT?
IF NOT ANYONE GOT INFO ON WHAT EXACTLY NEEDS TO BE CHANGED?
CHEERS MICKER!
Posted on: 2004/4/22 3:42
Re: WHATS THE DEAL WITH A15 FROM VANETTE?
From Portland, Vic
For a start, turn your caps lock off, as believe it or not, it doesn't make people more interested in your post.
Secondly, there's a little search panel on the side of the screen......
<-------Over there
Use that to find the info you need, as it has been covered on numerous occasions. It all depends on the year of your ute as to how easy the engine is to just 'bolt in'
Posted on: 2004/4/22 4:11
- 1985 Datsun 1200 Ute - S5 13b Turbo
From Christchurch NZ
Provideing that you ute was fitted with a " alternater on the drivers side" type engine it will bolt straight in.
Posted on: 2004/4/22 6:12
Forced Induction!
If your 1200 ute is a 1971-1973, no. If your ute is a 1974-or-newer, yes except for some minor wiring and emission hose routing, and (most importantly) the exhaust is about an inch higher, so the exhaust pipe might be a bit tight.
Posted on: 2004/4/22 6:57
also make sure its an A15 vanette and not an A12
Posted on: 2004/4/22 8:13
