« 1 (2)
Re: Help with brake setup for 1200 Ute.
the BETTER option is what you want. It is simply user preference.
Do you want a HARD pedal that takes more leg pressure to stop the car?
Do you want a car to stop quicker with LESS leg pressure?
Posted on: 2013/1/20 0:43
I'd say I'd like less pressure but not too much travel. So a happy medium?
If I installed a 7/8 which is the largest (meaning hard pedal but least amount of travel), coupled with a booster which means not as much pressure required would give best of both worlds? Yay or nay?
Posted on: 2013/1/20 5:36
Well a booster always softens up the pedal a bit. Some do not like the feel of a booster, but in general it is a good compromise.
Posted on: 2013/1/20 6:34
Go the 13/16 then no booster
Posted on: 2013/1/20 7:02
From Geelong, Vic
sunny booster is also an option. any of the relatively small boosters will still give plenty of pedal feel, id say on my car you have better pedal feel with the booster than without. As without the booster the pedal was just rock solid all the time and you physically couldnt get the car to stop anywhere near as good as it should. mind you that was with r32 brakes all round adn a 15/16th master
but i feel the booster made the car stop far better and gave you more feel for how much pressure you were actually applying
i also had landcruiser front brakes and r31 rears with a 7/8th master with no booster and that pedal was almost to stiff for street driving
but thats just me, im yet to drive a car that isnt running a booster that i think stops nicely. i like to be able to pull the car up confidently using just the force from my little toe on the pedal
13/16th master that will be a straight bolt in replacement will come from a datsun sunny, providing you already have a dual res master cylinder in the car currently. Easy enough to just go to a brake place and look through a master cylinder book. just look at the datsun ones from the 70s and 80s in the size you want. if they look the same as the ones you have now then there is a very good chance they will be a bolt in replacement
Posted on: 2013/1/20 11:30
Awesome thanks guys. I'm thinking a 13/16 with a booster is the go. Like I said, my previous coupe had TRX Bluebird discs all round with a booster and I didn't mind the feel of how it stopped. It actually could have stopped a little easier with the same pressure for my liking. It had a '84 TRX MC with a 120y booster.
PIGDOG when you say "Sunny" which model specifically so I know what I'm looking for?
Posted on: 2013/1/20 11:42
From Geelong, Vic
310 sunny
Posted on: 2013/1/20 11:43
« 1 (2)
