« 1 ... 13 14 15 (16) 17 18 19 20 »
Re: rocketrod's 1200
From Nyngan, nsw Australia
any you lads fitted these S13 clusters gauges with any problems
Posted on: 2013/1/7 12:26
living is good,.....
From MOOROODUC. Victoria
See my build thread
also I have added the cruise control buttons out of a 1995 bluebird u13, will update pics later
Posted on: 2013/1/7 23:12
still like to hear from anyone fitted the S13 cluster to there 1200
finally put sign up...
Posted on: 2013/1/13 4:56
getting closer to a finish
Posted on: 2013/1/23 23:21
How do you go with the wing mirror placed there... I put mine in a similar position and then could not adjust them to see properly ... then had to move them and fill and repaint - not fun
Posted on: 2013/1/23 23:34
yeah no probs seeing, iam tall, also able to open 1/4 window fully
Posted on: 2013/1/23 23:56
From Canberra
I have the same mirrors and still undecided where to put them either on the quater panels or on the door they seem a little hard to see out of when i have mocked them up on the door as when on the quater they are alot easier to see but then can't exactly adjust them if in the car driving
Posted on: 2013/1/24 4:30
yeah i thought fitting to top of the guards, no good, found you need long neck mirrors to miss the bonnet when opening
Posted on: 2013/1/24 5:27
check with the roadworthy rules before you put any mirrors on your guards - if it wasn't an original option it may not be allowed
Posted on: 2013/1/24 5:55
From Canberra
Mhmm might have to double check to see if it will miss the bonnet...
And the ute is a 1971 and it had the original guard mirrors on the car when i purchased it 4 years ago
Posted on: 2013/1/24 22:56
