« 1 (2) 3 »
Re: Where to buy or get made the 2 outer tie rods?
So they are not hard to find at all. Both Nissan and SuperCheap and other local auto parts stores sell them.
Posted on: 2013/1/29 20:03
From Narellan,Sydney
Just rang Nissan they told there is none in the country ATM.thanks supafatto that would be good
Posted on: 2013/1/29 23:36
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
Yes Nissan has to order them, even here.
Posted on: 2013/1/30 1:33
IF you need em in a mad rush I've got a complete set here new (non genuine) that I won't be installing for a little while (so in other words I have time to replace them).
Auto1 got them in for me. I don't recall what they cost, but you can have them for cost and postage (I'll work out what the cost is when I re-order them, but I can have em headed your way this week, they'd get there around monday/tuesday depending on the floods (actually that might be a problem now that I think about it)
Posted on: 2013/1/30 5:11
John McKenzie
From sydney australia
try Wholesale Suspension
129 Coreen Ave, Penrith NSW 2750
ph: (02) 4721 2112
I got Sunny inner tie rod ends & 180b outer tie rod ends from them a few years ago without a problem. Maybe they have an agent closer to you, though the Repco manager at Narellan suggested I go there at that time(Hi Dave).
Posted on: 2013/1/30 9:50
Thanks heaps jmac but it's not a massive rush cars still in the build.will ring auto 1 tomorrow tho.b310gx thanks but I'm after the rods them selfs not the rod ends
Posted on: 2013/1/30 11:01
Ah so the threaded rods that join the inner and outer tie rods together?
Posted on: 2013/1/30 11:07
Yep that's it
Posted on: 2013/1/30 11:32
That is called the "tie rod"
Aka Side Rod, Tie Rod, Adjusting Sleeve, Tie Rod Adjuster, or Steering Linkage Adjuster. The ends are left- and right-threaded.
GM part number 88910767
Posted on: 2013/1/30 19:26
Yes exactly dd which is why in my 1st post I have asked for the "tie rod"
Posted on: 2013/1/30 20:38
« 1 (2) 3 »
