Fast Search Slow Search
Google Ad |
Browsing this Thread:
1 Anonymous Users
#1
A15 Head Bolts
uteboy1200
Posted on: 2013/1/30 6:53
I'm looking for a new set of head bolts for my A15. I live in australia and can't seem to find any. I snapped one tightening it yesterday. I used the tension settings for A15 but this motor has an A12 head and weaker bolts. I realised all too late. Am i better off getting A15 bolts and if so where from?
#3
Re: A15 Head Bolts
Posted on: 2013/1/30 7:11
ARP does not sell head bolts
A15 uses the same bolts as later A12. Just make sure thet are the strong Cromoly V bolts, marked with 13 on the head.
#4
Re: A15 Head Bolts
uteboy1200
Posted on: 2013/1/30 7:14
Cheers. Looked at site and they do A14 head studs. I'm pretty sure they are the same. Now should I tension to A12 or A14 specs?
#5
Re: A15 Head Bolts
bige
Posted on: 2013/1/30 7:28
A15 ARP HEAD STUD KIT, I'VE GOT SOME IN STOCK . PM ME IF INTERESTED
#6
Re: A15 Head Bolts
pjz
Posted on: 2013/1/30 14:34
Use the tightening specs for the bolt you are using. Early A12 head bolts have "12" on the head of the bolt and are not as good as the A14/15. The A14/15 bolts have a "13" on the head. The "13" are better. The "13" bolts will accept 54 lb-ft where the "12" bolts only 42 or 43 lb-ft. [Check the torque spec for "T" bolts.]
If using the ARP studs, follow the directions. ARP gives different tightening specs depending on if the nut/bolt uses ARP lube or something like motor oil. I re-use "13" style head bolts if they are in good condition. Peter
#7
Re: A15 Head Bolts
uteboy1200
Posted on: 2013/2/11 0:26
Thanks all! Cheers for the offer Peter. I got on to some direct from NISSAN. They are second hand but did the job. Go the Dato!!
