New A Series Engine Rebuild Kits
From sydney.nsw
A10/A12/A13/A14/A15 "rebuild kits" with a15 cast dish pistons, a14 hi comp,a12 flat top/rings/conrods,mains,cam bearings/gaskets/timing kit. can make up kit to suit your sizes you need. starting for $450.00.
Can also do separate items. if required
Also got a set of NEW ross forged a15 78mm flat top pistons with pins & clips &
valve reliefs (30mm c/h) & total seal race rings.custom made.
Also got engine parts; heads/cams/cranks/ sumps/rockers .all other parts as well.
"i can also build your engine or you can build it yourself"
pm if interested. cheers
http://datsun1200.com/uploads/newbb/9764_4ea936c25e889.jpg
Posted on: 2013/1/31 5:22
Edited by bige on 2013/1/31 5:50:05
Edited by bige on 2013/1/31 5:50:38
Edited by bige on 2013/1/31 6:48:41
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
Re: New A Series Rebuild Kits
From Freo
Big E's killer motors...
Posted on: 2013/1/31 5:40
A15 PSI Project Motor
'72 CB750k,
Whats the price on those a15 forgies?
Posted on: 2013/1/31 6:18
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
From sydney.nsw
PM Sent,
Posted on: 2013/1/31 6:24
Re: New A Series Engine Rebuild Kits
From Freo
Posted on: 2013/1/31 7:08
'72 CB750k,
From sydney.nsw
thanks mick.
Posted on: 2013/1/31 7:38
Quite a regular
From neerim east victoria
Hi bige would you have a rocker shaft for an a12?
tks Russ
Posted on: 2013/1/31 21:45
From sydney.nsw
yes got some good s/h ones.where r u located.cheers
Posted on: 2013/1/31 23:38
Quite a regular
Neerim East Victoria pc 3831 how much for a good 1 + postage
tks Russ
Posted on: 2013/2/1 4:27
From sydney.nsw
pm sent russ
Posted on: 2013/2/1 4:55
