« 1 2 (3)
Re: Where to buy or get made the 2 outer tie rods?
So you don't need "outer tie rods" which people commonly call the outer rod ends, but only the rods themselves.
All use the same tie rods B110, B210, 1600, 180B, 160J.
Posted on: 2013/1/31 2:07
Gosh I'm sorry - I honestly thought you meant the tie rod ends as well wehn you mentioned the word 'outer'.
Not to worry though, I've got a spare set you can have.
Failing that, you can get steel bar cheap enough and you can get left hand thread dies to (the rh thread ones are easy to find) cut the thread - I forget if it was m12 or m14 but I know I can get em in melbourne in left hand thread (I looked into this a while back when toying with making a couple of custom control arms that were longer than stock to increase track and camber at the same time)
If you need a set of tie rods, you can have a pair for postage costs. Let me know via pm if so.
Posted on: 2013/1/31 6:55
John McKenzie
From Narellan,Sydney
Thanks guys and jmac but I'll just wait to order the whole thing from Nissan.thanks anyway
Posted on: 2013/2/1 6:33
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
« 1 2 (3)
