« 1 ... 3 4 5 (6) 7 8 »
Re: My CA18DET powered 1200 ute setup to run E85
From Flinders View, QLD
Got an extra day off due to the floods so I decided to make my battery cradle. I still need to weld some gussets on the sides of the cradle and make some backing plates to go on the bolts inside the vehicle to strengthen them up. It sits nicely were the origional fuel tank was now. Next job is to sort out the hand brake cables/setup.
jpg  BATTERY CRADLE.jpg (82.04 KB)
5996_5107aa36e0e8c.jpg 880X660 px
jpg  BATTERY CRADLE1.jpg (110.01 KB)
5996_5107aa886438d.jpg 880X660 px
jpg  BATTERY CRADLE2.jpg (107.76 KB)
5996_5107aab4125f5.jpg 880X660 px
Posted on: 2013/1/29 10:55
Just trying to put the bloody puzzel back together
From Townsville
Hey Mate, Just read your thread, looks like a great little datto you got going there..
Are you in Townsville or Ipswitch? Im up here in Townsville and looking to buy my 3rd Datto ute soon haha These things are awesome..
If you ever need advice or a hand with anything, just ask..
Brad
Posted on: 2013/2/6 3:10
Hay BradsDatto, I am in Ipswich so I am guessing the offer of help may be out now but thanks anyways... This is my first datto and 4 cylinder so its a bit different for me but its heeps of fun playing with such small cars, everything is light and easy. When you get your third project you'll have to start a thread in the project builds.
Posted on: 2013/2/6 11:17
From Townsville
Haha oh well mate, maybe I'll be down your way sometime soon and I'll pop in and say hey and check it out..
Great Job by the way..
Posted on: 2013/2/6 11:33
Cheers mate. If your ever in the neighbour hood drop by.
Posted on: 2013/2/6 23:16
Done a tad more to the battery cradle by adding the side gussets. Next step is to measure up the hand brake bracket and weld it on.
jpg  BATTERY CRADLE3.jpg (121.46 KB)
5996_5135c4e21fd63.jpg 920X690 px
Posted on: 2013/3/5 10:12
Once I have finished with the battery cradle and handbrake I might fit this setup into the engine bay... ...SOMEWHERE?????????
The first pic is my complete set up minus the 2x5in cooling fans. Second and third pic are of the oil filter landing I modified. I spent a few months surfing forums, ebay and calling wreaking yards and could not find non oilcooler set up so I finally cracked it. I pressed a piece of 5mm alloy plate into a dome shape, for a little better oil flow with-in the housing and a mate TIG welded it up. Didnt turn out too bad but TIGing the cast alloy housing was a pain.
jpg  REMOTE OIL FILTER01.jpg (162.28 KB)
5996_5135c5882ca02.jpg 920X690 px
jpg  REMOTE OIL FILTER02.jpg (147.41 KB)
5996_5135c6a0bc80e.jpg 920X690 px
jpg  REMOTE OIL FILTER03.jpg (138.27 KB)
5996_5135c6b12d405.jpg 920X690 px
Posted on: 2013/3/5 10:19
From Brisbane
Nice work mate.
Have you fitted your billet fuel rail yet? I ended up getting one but I need to shorten the spacers, just seeing if you had the same issue.
Posted on: 2013/3/5 11:00
Havent fitted the fuel rail yet, once I finish the oilcooler setup I can attach the intake and start plumbing the fuel lines.
What injectors you running? maybe there is some height variences with different injectors, I am running ID1000's.
Might get to in within the next month... HOPEFULLY :)
Posted on: 2013/3/5 11:06
From Brisbane
I have ID2000's, only need to take a couple of mm off the shorter set of spacers.
Posted on: 2013/3/5 11:36
