a12 auto + a14 or a15
From Sydney Australia
Will an a12 auto gearbox pattern be the same as an a14 or a15's engine pattern?
Will it be strong enough???
Posted on: 2004/4/19 14:01
Currently own a 73 1200 with sr20de and a 71 1200 with almost finished a14 blow through
Re: a12 auto + a14 or a15
Yes, the A12 bellhousing pattern is the same as the A14 and A15.
All these engines use the JATCO 3N71A, right?
Posted on: 2004/4/19 17:26
Cheers for the info ddgonzal!!!!
Does anyone know if the a12 auto will be strong enough for an a14 or a15???
Can it be made strong enough??
Posted on: 2004/4/20 11:07
From Invercargill, New Zealand
Yes it is strong enough - they are a very rugged box and were used behind the A12 and A15 Sunny's in NZ. I have both models and was happy to find the trans is based on the C4.
Info from rgrinder on earlier post : early A series up to 1973 if I remember correctly used an automtic trans made by Borg Warner, then Nissan switched to one made by JATCO, stands for Japanese Automatic Transmission COmpany.
JATCO was a joint venture between Nissan and Mazda, both owning 50%.
the Borg warner unit and the JATCO unit were both 3 speeds, out of the 2 the JATCO is a much better trans. the Borg units would self destruct as you drove them, where as the JATCO unit was/is very similar to a Ford C4 and almost bullit proof, the only thing that seems to go wrong with them is that the vacuum modulator diaphram ruptures and ATF gets sucked into the intake manifold, causing them to not shift right and the engine to billow clouds of oil smoke.
as far as I know of, there was not a 4 speed auto available for the A series. 4 speed autos didn't show up until the mid 1980's, by then Nissan had stopped using the A series in any great numbers to make it profitable to do the design and engineering.
Posted on: 2004/4/20 13:29
Cheers sounds like you are a bit of an expert on this!!
My auto is in a 71 model 1200 so i gues its the one that self destructs!!!
Is the JATCO one easy to get is AUS?
Posted on: 2004/4/21 12:17
If i remember rightly, the Auto in my mother in laws '69 Datsun 1000 was a JATCO, & i believe that Aussie 1200's were the same.
Mother in law? Yeah, back in the '80's between my wife, her mother, & me, we had a '68 Datsun 1000 two door, a '68 four door, a '69 four door, & a '73 Datsun 1200 ute, all at the same time.
We loved out little Datsuns. Still do.
Posted on: 2004/4/21 15:44
Love your Datsun.
Treat it well.
Yes, P510s used Borg Warners, then switched to JATCO. My '69 P510 1600 wagon had a two-speed automatic! But 1200s used JATCO 3N71x to start with.
Posted on: 2004/4/21 16:59
Sweet cheers for that everyone!
Any way to easily ID these gearboxes??
Posted on: 2004/4/24 16:02
From Sydney, Australia
Yeah, hurry up and put it in your car..if it self destructs..then you'll know.
I seriously don't think gearbox strength will be a problem for you. Most Autos are way tougher (and lots heavier) than their manual G/B counterparts.
Get it in..and get croooozin.
Posted on: 2004/4/24 23:18
