Re: Widest Rims that will fit a 1200 GX Coupe?
From South Africa
No cutting. I still await my shortened axle. As for the body, I welded supports in between the "chassis", if you want to call it that, making it look somewhat like a ladder, and simply shifted the springs to attach to two of the cross beams.
The suspension is stiffer with the the retentioned leafs and smaller coil-overs up front. I've rolled out the guards a bit but I don't count on it to make too much of a difference. She's currently running on 175/70 R13x5 no scrubbing.
What do I need to do to get 13" x10"s in front?
What tire size would be appropriate?
How close can I get to the original overall wheel diameter?
Thank You Gentlemen
PS: I'd really appreciate any links to examples
Posted on: 2013/2/11 5:40
Subject Poster Date
     Widest Rims that will fit a 1200 GX Coupe? Liebonhardus 2013/2/10 12:09
       Re: Widest Rims that will fit a 1200 GX Coupe? CGS1948 2013/2/10 17:59
         Re: Widest Rims that will fit a 1200 GX Coupe? townie 2013/2/10 21:16
       Re: Widest Rims that will fit a 1200 GX Coupe? Datrotor 2013/2/11 1:41
         Re: Widest Rims that will fit a 1200 GX Coupe? ddgonzal 2013/2/11 3:43
           Re: Widest Rims that will fit a 1200 GX Coupe? benny 2013/2/11 3:46
           Re: Widest Rims that will fit a 1200 GX Coupe? ddgonzal 2013/2/11 3:53
       Re: Widest Rims that will fit a 1200 GX Coupe? Liebonhardus 2013/2/11 5:40
         Re: Widest Rims that will fit a 1200 GX Coupe? ddgonzal 2013/2/11 6:00
