« 1 ... 3 4 5 (6) 7 8 9 »
#51 Re: Toying with oot
lightload Posted on: 2013/1/28 10:22
Its rough but getting there.
Was very happy that the exhaust manifold off the rx7 fitted... just... has about 3mm of clearance against the steering box.
And I'm hoping the oil cooler behind the rego plate wont stand out too much but all seems to be going smoothly so far. Just wish I had more time to work on it. Also wish it was in my own shed and that I had a shed, instead of one on the other side of town.
#52 Re: Toying with oot
Posted on: 2013/1/28 10:30
Paint the.cooler black.
#53 Re: Toying with oot
lightload Posted on: 2013/2/11 10:29
One day I'm gonna build a show car.... that day is not in the foreseeable future. So instead I build an ugly trans tunnel.
Oh and my tail shaft has arrived. Looks beefy.
#54 Re: Toying with oot
CA_1200_project Posted on: 2013/2/11 10:51
I did my own trans tunnel a while ago and it is no easy task. I'm more than happy with it tho. What material are you using there? Looks like .8?
Nice work on slotting the engine and box in
Chuck some decent plates on the gb mounts inside to spread the load out.
I know what its like doing work out of someone elses shop/shed thats ages away but keep chugging away mate...
Keep up the good work
#55 Re: Toying with oot
lightload Posted on: 2013/2/11 12:30
Thanks mate.
Material is a little thick about 1mm I think, a friend makes aftermarket sumps and works at a truck body shop so grabbed some "semi galvanized" sheet out the bin for me and put a few bends in it to get me started. Yeah got some 50x50 washers to weld nuts to that will be tacked to the floor.
#56 Re: Toying with oot
lightload Posted on: 2013/2/17 9:48
Motor is in for final time I hope.
Tunnel took way longer than expected but once painted it looked a lot better than I thought it was going to.
Still need to do clutch pluming and make exhaust but almost all connections are done and its ready to turn over with some water and oil.
Was very tempted to start it tonight but not sure about db levels with just a manifold on a twin rotor in a shed.
Kinda spewing I didn't get it finished as I will be cutting down some 8m gums around the house next weekend and probably wont have a chance to get it finished.
#57 Re: Toying with oot
lightload Posted on: 2013/3/3 11:19
Its alive...
My exhaust sounds poo, got water leak from radiator hose that's on a angle. Oil leak from copper pipe weld that wasn't hot enough and needs a tune... but it starts first time and runs with a bit of choke.
#58 Re: Toying with oot
Posted on: 2013/3/3 20:50
Good stuff, minor issues you will overcome easily IM sure
#59 Re: Toying with oot
lightload Posted on: 2013/3/12 11:48
Finished and loving it.
Exhaust sounds killer now.... for a rotary.
Goes awesome, needs a tacho and carpet. Doesn't feel like it needs a tune but haven't checked plugs yet.
Stoked with the ease and result of this build.
Downside is the front is now too low.
#60 Re: Toying with oot
Stock1200Ute1 Posted on: 2013/3/12 21:37
Nice work mate!
Has been good watching this build progress, i love the work!
Too low in the front, thats easy fixed! Lower the back more :P
Would love to see some vid of the car in action!
