« 1 (2) 3 4 5 ... 11 »
Re: [EOI] - Flex-Form Composite Leaf Springs Group Buy
Still waiting on a reply from Mark about alternative shipping methods but so far
1.oda70
2.fiasss
3.townie
4.ogyris
5.sikyne
6.D
7.ruredi (me of course)
So another set and we have the group discount.
Would have to make enquiries about the Import Duty Tax but sending them in sets of 2 would make postage $80-$90 making a pair $470-$480 which still isn't too bad.
We need more info on what the best specs would be to suit.
Posted on: 2013/2/9 13:29
From Western Australia
What is the general consensus in regard to ride height and spring rate?
Tramp control etc?
Surely different configurations will be needed to cater for the various body weight variations between ute/sedan/coupe/wagon shells and intended use of the vehicle eg street/drag/circuit/rally
Any ideas on what will be available?
Posted on: 2013/2/10 6:55
1200 Sedan SR17VE + TURBO (Borg Warner twin scroll), 6 Speed, Brembos, Autronic SM4 ...coming together slowly.
Stanza rally car mostly ex works = FIA head, 50mm Mikunis, option one, works diff, 4 pot FIA calipers and vented disc all round, enkies, h...
I think the best way would be to confirm all of the stock specifications for the different vehicles and then someone with the knowledge can tell us what dimensions need to be changed to achieve what. Can someone fill in the blanks for stock specs.
1200 SEDAN
A-dimension overall = "
B-dimension center pin = "
C-dimension arch height = "
D-dimension chord = "
E-dimension bolt diameter front = , back =
F-dimension width =
Spring Rate:
Axle Percent Rate:
Car weight:
1200 COUPE
F-dimension width =
Spring Rate:
Axle Percent Rate:
Car weight:
1200 WAGON
F-dimension width =
Spring Rate:
Axle Percent Rate:
Car weight:
1200 UTE
F-dimension width =
Spring Rate:
Axle Percent Rate:
Car weight:
I believe D is after a set for his KB10 Wagon? D can you confirm?
1000 WAGON
F-dimension width =
Spring Rate:
Axle Percent Rate:
Car weight:
Posted on: 2013/2/10 8:10
Latest reply from Mark.
Hello Joey,
The springs come complete with polyurethane bushings and center isolators/pins. They are ready to install with the vehicle’s bolts.
We can pack 3 pairs to a package. The quotes I’ve gotten have varied quite a bit based on the number of parcels to be shipped together, so I’m wondering if you can final quote shipping and take shipping payment from your group at the time when you have finalized the quantity. Also, minimum weight requirements for ocean freight are keeping those quotes higher than for air freight unless the quantity goes up substantially.
Current best pricing for two parcels is $445.00. Price per parcel improves somewhat with a third package. There are a couple of quotes remaining that could be better once a quantity is finalized.
Thanks,
Posted on: 2013/2/14 18:17
From Brisbane
Im running 250lb fronts thinking 200lb spring rear for the ute.
Posted on: 2013/2/15 11:17
From Brisbane
Does anyone from brisbane want to order some.? will be ordering my set tuesday night. Different spring rate doesnt matter. decided to go with 210lb to keep it close to stock ute rate.
Posted on: 2013/2/25 1:48
Oda70 do you have the exact measurements and specs of the stock springs for the ute?
Posted on: 2013/2/25 3:04
From Brisbane, Australia
210lb/in is a very high rear spring rate. I'd be double checking your info before ordering.
Posted on: 2013/2/25 3:24
Edited by L18_B110 on 2016/3/31 23:39:55
From Brisbane
I read on the wiki that a stock spring rate for the 1200 was 109 lb/in in the rear - the ute would be a bit more but not much I expect.
Oda, I'm in bris, we can order them together when we hear back from Mark about costs.
It would be a question of whether a bulk shipment is more expensive than ordering in pairs to avoid the 20% import tax (plus domestic freight to door).
Posted on: 2013/2/25 3:56
standard front spring rate is 89lb. and weight distribution is something like 55:45 standard. I'd be surprised if the rear spring rate was higher than the front from factory.
The Pitroad #23 TS Cup B310 Sunny race car with massive 9" rear wheels and full slicks run about 3kg (165lb/in) rear springs.
The NISMO rear spring for B310s is 125lb. You'd probably be alot better off with that sort of rate in a modified road car.
Posted on: 2013/2/25 4:11
Edited by L18_B110 on 2016/3/31 23:40:25
