Browsing this Thread:
1 Anonymous Users
A14 fresh rebore, new pistons, new gaskets, in pieces no head. |
From illawarra, nsw australia
Hi all. First post in a while but have some bits for sale All located in warilla, NSW. But will put on a truck at buyers cost. Will have some general freight quotes tomorrow
Sad to see it all go but just not in the datsun game anymore. Have an a14 block rebore, 2 sizes over. New high comp pistons to suit plus rings New bearing kit. standard size bearings. Gasket kit. no head unfortunately for motor.. have other bits must check tomorrow. All in pieces Good start for a hot motor build.
Also have 32/36 Webber with oval port manifold in great condition
Have other bits.. collected all this stuff for a build but things changed, all in good nick never been used.
Also have a straight 120y front bumper chrome pealing a little bit.
Motor and all bits $450 Carbi $150 Both for $550 Bumper $make an offer
Pics up asap Pm or ph: 0421834559, will return missed calls Thanks j.
Posted on: 2013/2/19 11:53
Re: A14 fresh rebore, new pistons, new gaskets, in pieces no head. |
Should also mention I have std crank, connecting rods, camshaft, flywheel
Posted on: 2013/2/20 1:49
datsunless. for now
Ok So having some dramas uploading photos. But i am happy to email anyone interested, most of the stuff I am listing is brand new and never used.
list of parts included with a14 block. *A14 rebore, 2 sizes over everything below is new and never used. most stuff still in plastic wrap. *correct size pistons and rings. high comp 7cc alloy. *timing chain and tensioner. *full gasket kit, includes head gasket, manifold gaskets, oil pump gasket. sump gasket, front and rear main seals, rocker cover gasket. *std size bearings. old ones were perfect when i pulled them out. (main bearings and connecting rod bearings)
everything listed below came off the motor, so it is standard. *oil pump *thermostat housing and thermostat. *connecting rods (old pistons still attached) *rocker cover *oil sump *crank with the bearing caps. *camshaft *flywheel
pretty much all other little bits and pieces are included.
PM email address for photos.
EDIT: will include a 120y manual which has just about everything needed to build motor,
Posted on: 2013/2/21 9:32
Good prices
Posted on: 2013/2/21 11:29
