Vacuum Advance
From Malaysia
what's the funtion of this vacuum advance? accidentally remove from it's location (shown in pic). Noticed the diapraghm leak but no ide when it happened but ignore it bcoz no effect on the engine before.
Recently engine cannot idle in low rpm.
Anything to do with engine idling vs the stuff?
already change the carb but still goes the same story.Engine not idle at all in low rpm.
Any expert will help me..
jpg  vac_001.jpg (12.10 KB)
11135_512b0f35678a4.jpg 160X120 px
jpg  vac_002.jpg (13.17 KB)
11135_512b0fa68432c.jpg 160X120 px
jpg  vac_003.jpg (31.82 KB)
11135_512b0faeb333c.jpg 448X336 px
Posted on: 2013/2/25 7:23
Re: Vacuum Advance
The function of vaccuum advance is to advance the spark under high-vacuum conditions. More spark advance = more power. But high vaccuum only occurs at part throttle, so it does not affect full-throttle operation in any way.
If the diaphragm is leaking, disconnnect the hose and plug it.
Your engine will run fine without vacuum advance. Just with a little less part-throttle HP and a little less fuel economy.
This is EGR, not vacuum advance:
Since it has broken off, unbolt the rest of the flange from the engine and fit a new EGR valve. Or remove and bolt a block-off plate of custom fabrication. Also disconnnect the hose and plug it.
Posted on: 2013/2/25 22:12
Edited by ddgonzal on 2013/2/25 22:45:33
Re: Vacuum Advance
From Malaysia
thanks dd, great help.
Posted on: 2013/2/26 15:13
