Browsing this Thread:
1 Anonymous Users
63A speedo question |
Quite a regular
From western Canada
Will oil leak ot of the speedo input if I drive my 210 without the speedo installed? Havin trouble getting it to fit without beating out the trans tunnel.
Cheers
Posted on: 2013/3/1 23:07
Re: 63A speedo question |
You will get some leakage from my experience. And yes it's a tight fit in a manual tunnel. Worth it though as it's,a strong box
Posted on: 2013/3/1 23:43
Registered Users Contentmaster Usermaster
If the speedometer cable is disconnected from teh transmission, it won't leak oil at the Speedometer. It will leak oil out of the transmission unless you cap it.
Posted on: 2013/3/2 0:44
Quite a regular
From western Canada
Nice one gents. Working on a 90 degree adapter for the speedo cable to fit into the 63A tranny. Motor is running amazing with the PZ H89 head and tuning of the 32/36. Not running forged bottom end so unsure as to what I should be pushing the car to RPM wise. But everything is else is comin together nicely.
Posted on: 2013/3/4 18:10
Stock A-series bottom end can run to 9500 RPM, but I suggest limiting it to 8500 RPM just to be safe.
Posted on: 2013/3/4 20:26
