L20B pollution control
From Melbourne, Aus.
Posted on: 2013/3/6 12:06
Edited by crumb on 2015/1/22 21:56:55
Re: L20B pollution control
Came out in 1974 til 1985
wiki
Not sure if that's accurate for aus. But the earlier the better
Posted on: 2013/3/6 20:32
In aus 1977 200b was earliest unfortunately with l20b
Posted on: 2013/3/6 20:44
Posted on: 2013/3/6 23:56
Edited by crumb on 2015/1/22 21:57:08
From Adelaide
Can you fit the L20B crank/ rods/ pistons in an L18 block? Maybe a way around it? I dunno personally.
Posted on: 2013/3/7 3:34
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
Block is 20mm taller for l20b.
Pcv shouldn't be too hard
Posted on: 2013/3/7 3:53
From Adelaide
There you go.
Posted on: 2013/3/7 5:06
Good idea but i really want to keep the block i have as is has had a bit of work done to it, I should have most of the bit and pieces to fit. Just really time poor at the moment and looking for the easy option if it existed.
Wont be hard but just finding time is.
Posted on: 2013/3/7 5:07
Read this
But pretty much post July 1976 is bad. You want pre 76 which is not possible so technically you need pcv, carbon canister and all the yucky pollution stuff. Knew there was another reason for straight Lpg
Posted on: 2013/3/7 6:32
