Browsing this Thread:
2 Anonymous Users
Re: fuel leak |
Mate no offence intended but read this, have a little think and just do a simple 10 second check. Grab the brass fitting firmly and give it a wriggle. If it feels even a little tiny bit loose the leak is between the fitting and the alloy body. Ford had a recall on these exact same carbs in the late 1970's for EXACTLY this problem when several 2.0 Escorts and Cortinas got more than a bit warm. Cause of the problem was people levering hoses off the fittings and loosening them. It still happens today.
Posted on: 2013/2/23 1:59
Re: fuel leak |
Quite a regular
From Adelaide
I felt the brass fitting and it moved a tiny little bit. Any way to stop it from wriggling?
Posted on: 2013/2/26 6:08
Re: fuel leak |
Registered Users Contentmaster Usermaster
JB-Weld
Posted on: 2013/2/26 7:12
Re: fuel leak |
Quite a regular
From Adelaide
Will jb weld be alright on the webber?
Posted on: 2013/3/3 22:14
Re: fuel leak |
I have used it in the past with no troubles.
Posted on: 2013/3/3 23:42
Re: fuel leak |
Quite a regular
From Adelaide
Thanks for that! Put some on there and it has stopped the leak so far!
Such a life saver!!
Now onto the other issues... haha
Posted on: 2013/3/8 14:49
