« 1 (2)
Re: Wanted
From NSW South Coast
coupe and ute are tailsharfts are the same length but not interchangable as the yolk (diff end ) is bigger on a ute. I'm fairly sure a sunny one is the same as a ute though. Hope this helps.
olboy
Posted on: 2004/4/27 7:27
Re: Wanted
From Canberra
Can anyone confirm that the sunny tailshaft is the same as a 1200 ute tailshaft.
Cheers,
Paul.
Posted on: 2004/4/28 4:31
Re: Wanted
b310 uses H150 diff, same length as H145. Not sure if the tailshaft length is the same. Depends on the transmission.
Apparently the 74-up utes have the longer diff center (meaning shorter tailshaft).
Why would coupe and sedan use different length tailshafts? The wheelbase is the same. Auto and Manual shafts are different in some way.
Posted on: 2004/4/28 5:41
« 1 (2)
